Time Dependent Perturbation Problem
7 replies · 2K views
Diracobama2181
Consider a two-level atom with the state space spanned by the two orthonormal states $$|1>$$ and $$|2>$$, dipole-coupled to an external time dependent driving field E(t). After a unitary transformation to the “rotating frame”, the Hamiltonian reads $$H/\hbar = ∆ |2><2| − f(t)[ |2><1|+|1><2|]$$, where ∆ is the difference between the atomic transition frequency ω0 and the frequency of the nearly monochromatic driving field ω, and f(t) is proportional to the temporal envelope of the driving field: E(t) ∝ f(t) cos(ωt). Suppose that $$f(t) =\frac{ λ }{2 \sqrt{\pi} \tau}(e^{-(\frac{ t + T/2}{\tau})^2}+e^{-(\frac{ t - T/2}{\tau})^2})$$ . This represents two pulses of light of length τ hitting the system at times ∓T/2. Let us assume that the amplitude of the driving field ∝ λ is “very small”, and that the system starts out in the state |1>.
$$i\hbar c_1(t)=<1|H'|2>c_2(t)$$
$$i\hbar c_2(t)=-f(t)c_2(t)$$
I am assuming this is the interaction picture, so I start with $$|\psi>=c_1(t)|1>+c_2(t)|2>$$. Plugging this into the Schrödinger equation,
I get the equations $$i\hbar c_1(t)=<1|H'|2>c_2(t)$$ and $$i\hbar c_2(t)=<1|H'|2>c_1(t)$$. I am assuming H' (the perturbation) is $$H'= − f(t)[ |2><2|+|1><1|]$$. From there, I get $$i\hbar c_1(t)=-f(t)c_2(t)$$, and $$i\hbar c_2(t)=-f(t)c_2(t)$$. Am I missing anything so far? I just want to make sure I haven't made any faults before continuing my calculation. I know this is supposed to be a derivation of Ramsey Fringes, it that is any help.
The time dependent equation should be :
##i\hbar dc_m (t)/dt= \sum_n H'_{mn}c_n(t)## where $$H'_{mn}=<m|H'|n>$$
Note: Made a mistake writing the problem. It should be $$H'/\hbar = -f(t)[ |2><1|+|1><2|]$$.
Using that equation and my correction, I get
$$ idc_1(t)/dt=-f(t)c_2(t)$$ and
$$ idc_2(t)/dt=-f(t)c_1(t)$$
Any idea on how I would uncouple these? Usually, I could take the second derivative of one and substitute, but the f(t) term makes that inapplicable.
The diagonal term vanish and off diagonal terms survive with exponential factor(c.f Sakurai's Modern QM). You forgot to write :
##~i \hbar \mathbf{\dot c_1}= ...##
Try using Dyson Series or any other approximation technique
Ok, using a first order approximation, I get
$$c_1(t)=-\frac{i}{\hbar}\int_{-\infty}^{0}<1|(-\hbar f (t))(|2><1|+|1><2|)|2>dt$$
and
$$c_2(t)=-\frac{i}{\hbar}\int_{-\infty}^{0}<2|(-\hbar f(t))(|2><1|+|1><2|)|1>dt$$
or
$$c_1(t)=-\frac{i}{\hbar}\int_{-\infty}^{t}-\hbar f(t)dt$$
and
$$c_2(t)=-\frac{i}{\hbar}\int_{-\infty}^{t}-\hbar f(t)dt$$
Hence,
since $$C_1=1$$ and $$C_2=0$$ to zeroth order,
$$|\psi>=(1+c_1)|1>+c_2|2>$$.
Does this seem correct thus far?
and
or
and
Hence,
Seems alright to me
If you have done correctly, then it's all right(I didn't check equation or integration)
