- 150
Here's what you wrote:Mark M said:How does this, in any way, contradict what I wrote?ghwellsjr said:You guys are taking a very simple concept and confusing it. In Special Relativity, whoever and whatever is moving in a particular reference frame is experiencing time dilation. It's not an issue of what observers see because no one can see time dilation, rather it's an assignment due to a specified frame of reference.
You have mentioned three different frames:Mark M said:I don't think you understand special relativity. Different observers disagree on the passage of time and length of objects in order to preserve a constant speed of light. You always see the clocks in your frame of reference as ticking normally, and measure objects as having the same length as in the rest frame. However, observers in a slower frame of reference see your clock ticking slower. Hence, they see your body processes occurring slower. There is no contradiction.
1) Your frame of reference.
2) The rest frame.
3) A slower frame of reference.
This is confusion. Look at this sentence:
Assuming that when you say "your frame of reference", you mean what everyone else means which is a frame in which you are at rest, then what do you mean by "the rest frame"?You always see the clocks in your frame of reference as ticking normally, and measure objects as having the same length as in the rest frame.
The first two frames apparently were at rest. What do you mean by "a slower frame of reference"?However, observers in a slower frame of reference see your clock ticking slower.
If you pick one frame and realize that all objects are in that frame, then it is very clear how much time dilation each object experiences simply by their speeds in that frame. You can then do it all over again and pick another frame moving with repect to the first one and recalculate all the speeds and derive a new set of time dilations. Assigning different objects exclusively to different frames is confusion.
