Time Dilation: A & B's Age Difference
7 replies · 2K views
jha192001
This is a gendenke experiment.
You(A) and your friend (B) are on earth. Now your friend sits on a spaceship that can fly at speed of 0.1c. He flies for 5 year straight ahead(away from earth) and then returns back slowly.
The answer that i get is B would have aged. Assuming this answer is right i want to put a question.
B goes. away from A and returns. But in reference frame of B, A goes away at 0.1c and returns so according to him A would have aged more. But when they meet who would have aged more? If no one, then how could wr say speed even has a effect called Time Dilation.
Thanks For Your Time.[emoji1]
Both would have aged, but B will be younger than A by about nine days.
B felt acceleration. A did not, remaining inertial for the whole experiment. Thus B cannot use naive time dilation results which are based on the use of inertial frames, since B was not at rest in an inertial frame for the whole experiment.
The one who felt acceleration will be younger. This is not a direct consequence of acceleration, by the way. Edit: see the article linked by Grinkle in the next post for details.
Sir,
B is in noninertial frame but as A is on Earth he himself is in one too..Then on what basis "B is youner" can be said.
P.s: I am reading about lorentz rn
jha192001 said:
Sir,
The Earth's surface rest frame is close enough to inertial that the error from treating it as inertial (Edit: or, more precisely, using the Sun-centred inertial frame and pretending that A is at rest in this frame) is tiny - about one part in 108, if I've done my mental arithmetic right. As to why B is younger, it doesn't really have anything to do with being inertial or not. It's just you can't naively apply standard SR time dilation formulae to non-inertial frames, which you were trying to do. Did you read the article Grinkle linked? It explains the age difference quite well.
If A were not on Earth but inertial, the age difference when he met up with B would be slightly more, as @Ibix noted.
If you are thinking that whether or not a frame is accelerating is frame dependent, this is incorrect. B felt acceleration according to B, and B felt acceleration according to A. They agree on this. A felt a much much smaller acceleration (being on Earth) according to A, and also according to B - they agree on that as well.
It has nothing to do with frames. It has to do with their different paths through spacetime. The twin paradox FAQ that @Nugatory linked to goes into all this. Please read it.
