Time for an object to fall to a larger one
  • Context: Graduate
  • Thread starter Thread starter kaikalii
    Fall Time
The discussion focuses on calculating the time it takes for an object to fall towards a larger body, specifically when the distance exceeds the Earth's radius. The equation of motion for short distances, x = -1/2gt² + vt + x, is insufficient for larger distances. Instead, the gravitational two-body problem and energy conservation principles are utilized, leading to the integral formulation for time calculation. The discussion highlights the complexity of non-linear equations and suggests using integral tables or WolframAlpha for solving the integrals involved.
  • Understanding of classical mechanics and gravitational forces
  • Familiarity with non-linear differential equations
  • Knowledge of energy conservation principles in physics
  • Experience with integral calculus and numerical methods
  • Study the gravitational two-body problem in classical mechanics
  • Learn about the Kepler problem and its applications
  • Explore numerical methods for solving differential equations
  • Utilize WolframAlpha for integral calculations and solutions
Physics students, researchers in classical mechanics, and anyone interested in advanced gravitational calculations and motion dynamics.
kaikalii
I know that for short distances from the Earth's surface, x=-1/2gt^2+vt+x works fine for finding the time it takes for an object to fall a certain distance ignoring air resistance.
However, what if the distance is many times the Earth's radius?
The only thing I can think of to start solving this problem is f''(t)=GM/(f(t))^2, but try as I might, I cannot solve that to evaluate the time and object takes to fall, say, a distance, r. How can I accomplish this?
I'm assuming you're talking about a body whose mass is much smaller than the Earth's, dropped with zero velocity from an arbitrary distance from the Earth. If so, please check out this article or this one. Basically the body follows a degenerate ellipse trajectory, similar to the trajectory of the moon around the earth. The equations aren't as easy to solve as the mgh potential because they're non linear, but if you want the time in terms of initial position, you write down the energy per unit mass, which is a conserved quantity (and should be negative if you're effectively falling and not escaping the Earth): E = E_0 = T + U = (dr/dt)^2/2 - \mu/r, solve for dt and integrate: $$ \int_{t_0}^t dt = t - t_0 = \int_{r_0}^r \frac{dr}{\sqrt{2(E_0+\mu /r)}} = \frac{1}{\sqrt{2\mu}}\int_{r_0}^r \sqrt{\frac{r}{1-\alpha r}}dr $$ with \alpha = -E_0/\mu > 0, if I didn't mess up the algebra. The integral may found in integral tables or WolframAlpha, or computed numerically.
For the more general problem where you can have non-zero velocity and a body with a large mass, read into the gravitational two-body problem, or the Kepler problem if you're not interested in large masses.
Thank you! This is exactly what I was looking for.
I've added some stuff to my answer, maybe you'd like to check it out :)
