Time for melting and vaporising a wax candle
  • Thread starter Thread starter kotchenski
    Melting Time Wax
The discussion revolves around calculating the time required for a wax candle to melt and vaporize under constant heat admission. The initial calculations focus on determining the heat required for melting using the equation Q=mL, resulting in a time of 21 minutes for melting. Participants clarify that the process involves multiple stages: heating the solid wax, melting it, heating the liquid to boiling, and finally vaporization. The correct approach combines all stages into a comprehensive heat calculation before applying the time formula Δt=Q/P. The conversation concludes with confirmation that the outlined method is appropriate for solving the problem.
kotchenski
Assume that a wax candle with mass m at temperature T1 undergoes constant heat admission dQ/dt=Kp
Assume:
m=50g
T1=25 celsius
Kp=10W
Calculate how long it will take for the wax to melt and vaporise during constant heat admission
without any loss.
Data:
ρ=791 kg/m3
M=310 g/mol
Tm=317.15 K (melting temperature)
Lf=252 kJ/kg
Tb=641.8 K (boiling temperature)
Lv=105 kJ/kg
Cp(s)=598.1 J/mol K
Cp(l)=739 J/mol K
Cp(g)=1193 J/mol K
P=Q/Δt
Q=mL
Q=mcΔT
Well the posibilities overwhelmes me.
I know that it all boils down to using Δt=Q/P the question is though which Q are they asking for, I have only made an attempt at the boiling question though.
For boiling
If I apply what I know from heat of transformation:
Q=mL
Q=0.05kg*252 kJ/kg -> Q=12600J
Thereby:
Δt=12600J/10W -> Δt=1260s
In other words it would take 21mins.
However if that's the case then it would be even faster to boil it away when it's in liquid.
Am I doing something wrong or is there something blatantly obvious that I don't seem to get?
kotchenski said:
Lf=252 kJ/kg
For boiling
Q=mL
Is this consistant?
Before plugging any numbers into equations, can you describe to me what will happen to the candle, from beginning to end?
DrClaude said:
Is this consistant?
I can see I said I would calculate the boiling, when I mean't I would calculate the melting.
The candle is in solid phase and it's placed in a isolated room which has the temperature of 25 celsius. I will now light the candle and have to calculate the time it will take the 50g of solid wax to become liquid.
I tried to calculate the time it would take for the candle to melt, and my guess for that was to use the equation Q=mL.
I here apply the constant Lf since the candle is going from solid to liquid state. The heat I calculate from that is 12.6 kJ or 12600J.
From that I then use Δt=Q/P
What I'm unsure about is whether or not I've done it correctly given the options that I have.
Ok.
You are not lighting the candle. You are supplying heat at a uniform rate. It is not the same thing.
But what happens before it becomes liquid?
That part is correct. But if you want to get through the problem, you first have to figure out everything that happens from beginning to end.
DrClaude said:
Ok.
I assume there are two stages then, the first stage is when the wax is heating which is expressed by:
Q= \frac{m C_p (s) (T_m-T_1)}{M}
The second stage would be when the wax reaches the melting temperature and begins to melt and so I add that to the equation so that Q will be:
Q= \frac{m C_p (s) (T_m-T_1)}{M} +mL_f
From this I can then apply my final formula:
\Delta t= \frac{Q}{P}
Would this be correct?
This is correct but incomplete. The problem asks for the time for complete vaporization.
Not entirely. I'm sorry if the translation is terrible but it's in danish. They ask for the time it takes for it to melt and then to vaporize. For vaporization I assume it would be in 4 stages:
1. Heating to reach the melting temperature.
2. Melting the wax.
3. Heating the liquid wax to the boiling temperature.
4. The wax is vaporizing.
This would give the heat calculation Q:
Q= \frac{m C_p (l) (T_b - T_m)}{M} + mL_v + \frac{m C_p (s) (T_m - T_1)}{M} + mL_f
And then it is just \Delta t = \frac{Q}{P}
Now I should be home free unless there is more to it.
2. Melting the wax.
Perfekt!
DrClaude said:
Perfekt!
You purposely searched up that word didn't ya? :D, regardless thanks for your help!
Nej, jag kan svenska.
You're welcome!
