Time is slower deep down in a potential well
Lifting a clock to a higher elevation requires work, resulting in increased gravitational energy that makes the clock tick faster. Conversely, time runs slower for a clock located deep in a potential well, as the potential energy reflects the work needed to lift it back to a higher position. The discussion questions whether the change in clock speed is due to the act of moving it or the gravitational effects of its location. It argues against the idea that clocks at different elevations should run the same if they are stationary, emphasizing that gravitational force, not kinetic energy, influences time. The conversation raises questions about how clocks perceive gravitational energy and whether the effects of movement would diminish once stationary.
Tesla
1) If you lift a clock to a greater height, you have to do work on it - the work done appears as gravitational energy stored in the clock; This shows up in the guise of extra tick-tock energy, as a result of which the clock ticks a bit faster.
2) Time is slower deep down in a potential well. Potential measures the work that it would take to haul something back out.
Tie a rope to it and lower it down a hole and it will run slower.
What matters is how much work it would take to haul it up and out.
Do you agree w/#1 and or #2 above?
Both of these points, which are not mine, make it seem that it is the act of moving the clock which changes its time to run either faster or slower, and not 'where' it is located.
So, a clock made on the top of a mountain, or made at the bottom of a mine shaft should run exactly like a clock located at the Earth's surface!?
No, not number 1. The change in the speed of the clock is due to gravitational force, not kenetic energy.
#1 is from Paul Davies book:
ABOUT TIME
Einstein's Unfinished Revolution
#1 & #2 make it appear that its the act of moving the clock that causes its time to run either faster of slower and not the gravity in that location.
If that is the case wouldn't the extra 'tick-tock' energy wear off after awhile with the clock now being stationary?
And how does the clock know how much energy it would take to haul it out, so it can slow down by that exact amout?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
