Time it takes for an electron to travel a set distance
The discussion revolves around the motion of electrons in a CRT tube, specifically focusing on calculating the speed of an electron after being accelerated by a potential difference and determining the time it takes for the electron to travel a specified distance. The subject area includes concepts from electromagnetism and kinematics.
  • Mixed
  • Participants explore different methods to calculate the time taken for an electron to travel a distance, with one participant initially using a straightforward approach based on speed and distance, while another delves into a more complex method involving acceleration and force. There is also a discussion about the use of average versus final velocity in calculations.
Participants are actively engaging in comparing their approaches to the problem. Some have provided calculations and expressed uncertainty about their methods, while others have pointed out considerations regarding the use of average velocity. There is a recognition of the validity of both methods discussed, although no explicit consensus on the correctness of the final answers has been reached.
Participants are working under the constraints of homework guidelines, which may influence their approaches and the level of detail they provide in their solutions. There is an ongoing examination of assumptions related to the motion of the electron and the formulas used in the calculations.
Reprisal35
In a CRT tube, electrons are accelerated by a 20,000 V potential difference between the electron gun (the cathode) and the positive metal mesh 5.00 cm away.
a. What is the electron’s speed when it reaches the positive wire mesh?
b. How much time does it take the electron to reach the wire mesh?
[itex]U = q∆V\\<br /> K = \frac{1}{2}mv^2\\<br /> F = ma\\<br /> F = qE \\<br /> E = \frac{V}{d}\\<br /> d = d_0 + (v_0)(t) + \frac{1}{2}(a)(t^2)\\[/itex]
For part A, I got the following which is actually the same example we did in class.
[itex] U = K\\<br /> q∆V = \frac{1}{2}mv^2\\<br /> (1.6*10^{-19}C)(20000\frac{J}{C}) = \frac{1}{2}(9.1*10^{-31}kg)(v^{2})\\<br /> 3.2*10^{-15}J = 4.55*10^{-31}kg(v^{2}) \\<br /> (3.2*10^{-15}J)/(4.55*10^{-31}kg) = v^{2} \\<br /> 7.033*10^{15}\frac{m^{2}}{s^{2}} = v^{2} \\<br /> v = √7.033*10^{15}\frac{m^{2}}{s^{2}} \\<br /> v = 8.386*10^{7}\frac{m}{s}\\[/itex]
Where I'm getting a bit paranoid is part B.
At first I thought, in order to get ##t##, all we needed to do was use the formula, ##t = \frac{d}{v}## and I got an answer of ##5.96*10^{-10}s##, but that seems to simple for this kind of problem.
So then I decided to use a combination of several formulas we learned in the past in order to determine the time it takes for an electron to travel a set distance.
Here's what I did:
[itex] F = ma\\<br /> F = qE \\<br /> E = \frac{V}{d}\\<br /> ma = \frac{qV}{d}\\<br /> a= \frac{qV}{dm}\\<br /> d = d_0 + (v_0)(t) + \frac{1}{2}(a)(t^2)\\<br /> d = \frac{1}{2}(a)(t^2)\\<br /> d = \frac{1}{2}[\frac{qV}{dm}](t^2)\\<br /> 2d = \frac{qV}{dm}(t^2)\\<br /> \frac{2d^{2}m}{qV} = t^2\\<br /> t = √\frac{2d^2m}{qV}\\<br /> t = √\frac{(2)(.05m)^{2}(9.1*10^{-31}kg)}{(1.6*10^{-19}C)(20,000\frac{J}{C})}\\<br /> t = √\frac{4.55*10^{-33}}{3.2*10^{-15}}\\<br /> t = √1.422*10^{-18}s\\<br /> t = 1.19*10^{-9}s\\[/itex]
Now looking back at my second attempt, it seems a bit ridiculous to do all that to get ##t##. So my question is, is my second attempt for getting ##t## correct or did I mess up?
Here's what I did:
Can you show your working to get your answer in the bit I made red, so we can check you did it correctly.
Sure,
[itex] d = 0.05m\\<br /> v = 8.386∗10^7\frac{m}{s}\\<br /> v = \frac{d}{t}\\<br /> t = \frac{d}{v}\\<br /> t = \frac{0.05m}{8.386∗10^7\frac{m}{s}}\\<br /> t = 5.96*10^{-10}s[/itex]
Reprisal35 said:
Sure,
OK, You have used the final velocity, not the average velocity.
Well that makes sense now.
[itex] v_{avg} = \frac{v_0 + v_f}{2}\\<br /> v_{avg} = \frac{0 + 8.386∗10^7}{2}\\<br /> v_{avg} = 4.193*10^7\\<br /> t = \frac{0.05}{4.193*10^7}\\<br /> t = 1.192*10^{-9}s[/itex]
I feel kinda silly for forgetting to take the avg of speed... Thanks for pointing that out!
So both methods give the same answer. Is it safe to assume both methods work and that the answer is correct?
Seems reasonable to me.
Awesome! Thanks again!
  • · Replies 16 ·
  • · Replies 17 ·
