Time of free fall does depend on mass
The discussion revolves around the relationship between the time of free fall and mass, particularly questioning whether the time taken for an object to reach the ground when dropped is influenced by its mass. Participants explore theoretical implications, experimental motivations, and the nuances of gravitational and inertial mass.
  • Some participants reference a lecture by Walter Lewin, suggesting that there is ongoing research into the dependence of free fall time on mass, despite traditional formulas indicating it should only depend on height.
  • One participant introduces the idea that gravitational and inertial mass might not be equivalent, questioning the implications of this on free fall time.
  • Another participant argues that both masses affect each other during free fall, suggesting that the time of fall could be influenced by the mass of both the falling object and the Earth.
  • Some participants express skepticism about the validity of the original question posed, suggesting it lacks clarity and depth.
  • There are claims that physics is an experimental science, emphasizing the need to verify existing formulas and theories through experimentation, even if they seem established.
  • A more accurate equation for free fall time is proposed, derived from Kepler's third law, which accounts for both the masses involved, though it is noted that this model has limitations.
  • Concerns are raised about the dimensional analysis used in the discussion, with one participant arguing that it may not be applied correctly in the context of proportional relationships.
Participants express a range of views, with no clear consensus on whether mass affects free fall time. Some support the idea of mass dependence, while others question the assumptions behind it. The discussion remains unresolved with multiple competing perspectives.
Limitations include the assumptions made about gravitational and inertial mass, the context in which formulas are applied, and the potential inaccuracies in dimensional analysis. The discussion highlights the complexity of the topic and the need for careful consideration of definitions and conditions.
  • #31
parshyaa said:
Sorry for this thread ,but he said that time of free fall does depends on mass , if any budy proved this then he will get a nobel prize and scientists are buisy to crack this. Suppose they have proved that yes it does depends on mass , then what will happen to the formula for time t, what is wrong in arguing that inertial mass and gravitational mass can be different[then this argument will raise a question how can a object have two mass] , oh god I am confused and making others too
@parshyaa (and Sophiecentaur) and whoever else...Maybe I can clarify a bit...Hopefully. It seems that the confusion is arising because there seems to be some confusion about which mass, (central mass or orbiting mass) you guys are referring to when commenting (it needs to be clarified) AND also because someone (Turtlemeister) used a "free -fall" equation based upon Kepler's 3rd law of ORBITAL motion...(which, BTW, is mass dependent) .. Let me explain>..and maybe it will help...maybe..LOL...It will require you to look at the equation briefly. OK, don't stop reading yet, this will be simple, not like my previous post.
Kepler's Law states (as mentioned by sophiecentaur) that an orbital planet sweeps out equal areas in equal times. What this means is that the orbital period, T, squared divided by the orbital Radius (or semi-major axis) CUBED is equal to a CONSTANT for ALL planets revolving around the CENTRAL MASS. Yes, amazingly the ratio of the orbital period squared to the orbital radius cubed is THE SAME value for ANY planet or asteroid or anything orbiting the sun.... Now what Sopie didn't mention is that this CONSTANT is equal to 4 (pi)^2 / GM...where M is the large Mass of the central body...(and G is the "gravitational constant".) This "Kepler" constant is dependent only on the central mass, say the sun for example, as long as the orbiting planets (or whatever) have "negligible" mass compared to the sun. As soon as a planet's mass becomes appreciable, then its mass, m, must be included in the calculation.
This Kepler orbital equation of motion can be manipulated to arrive at free-fall motion, (to which Turtlemeister alluded)...but this is not typical... This no doubt caused some confusion...
The amazing genius of Kepler's equation is that it is applicable for all bodies orbiting around the same central mass. For example,,,ALL satellites orbiting Earth must follow the same Kepler equation (except now using mass of Earth as big M) . IOW, all satellites with the same orbital radius must have the same orbital period...(and even satellites in elliptical orbits have the same orbital period provided we substitute its semi-major axis for radius, R.) This is because the formula depends only upon the mass of Earth and the satellites have "negligible" mass compared to that of earth.
Pres. Eisenhower in 1957, being greatly troubled, for example, when Russia sent the first orbiting satellite (Sputnik) over America, asked US scientists," How can we determine how big (how massive) this Russian satellite is?" The response was , "We can't ... even if we know its orbital period and orbital radius".
Why ? Because the mass of the orbiting satellite does not enter into the equation of motion...only that of the central mass, (earth) ...providing that the satellite isn't a big bugger like that on the movie "Independence Day" ! (LOL).
NOW, having said all that, the above stuff really says almost nothing about "gravitational" verses "inertial" mass. To really enter into that discussion you must start with NEWTON's equations...which deal with INERTIAL mass via F= ma...and combine it with gravitational Force equations like F= GMm / R^2... which gives the force between two masses.
I think I've said enough for now. Clear as mud, right?
Pet Scan
  • #32
During free fall : ma = GMm'/r^2 , I think Newtons gravitational formula is formed for rest masses of a object (I am not shure )
When object falls down, its velocity increases , therefore according to this formula[ m = m'/√ {1-(v^2/c^2)}] , as velocity increases mass of a object also increases (by a tiny amount) , therefore m in LHS is different from m' of RHS therefore a = GMm'/mr^2 , ∴ accelaration depends on mass and it tells that time also depends on mass(for a very very very very small fraction but it does depends on mass) , this is just my thinking , so somebudy please tell me what is wrong in this .
  • #33
Classical: Using Kepler's Law, which is the result of and inverse square law relationship is a bit dodgy, imo, when describing the behaviour of a 'through the Earth' pendulum, which involves a very different bit of Physics which gives a SHM.
I know that the resulting period is the same but, without some further detailed proof about the equivalence of the two processes (neither of which were discussed by Kepler, of course) it doesn't get us very far.
GR: In any case, the thread continues to hover between Classical and GR and Lewin's presentation is based on Classical and his Dimensional Analysis assumes things about the relationship that don't follow into GR. For a start, his time and distance variables will be changing in a GR way that he is not including in his lecture. This is all proving nothing.
  • #34
I just now had a chance to take a look at the section of Walter Lewin's lecture that the op is questioning. I think that the "very fancy experiments by very prestigious physicist" that he refers to are actually tests of the equivalence principle. And to be more precise, I think he is referring to tests of the equivalence principle as it relates to inertial and gravitational mass. Even though many of these tests have been performed by simply dropping objects from a height, this can only work when M>>m, such as M=Earth and m=any ordinary object. If you had an instrument sensitive enough (doesn't exist with current technology), or your test mass was massive enough, you could indeed detect a change in free fall time when the mass of the falling object is changed. You can see that in the equation that I posted.
Here's what the equivalence principle says:
Einstein's statement of the equality of inertial and gravitational mass:
A little reflection will show that the law of the equality of the inertial and gravitational mass is equivalent to the assertion that the acceleration imparted to a body by a gravitational field is independent of the nature of the body.
Notice that it says the acceleration imparted to a body by a gravitational field is independent of the nature of the body. So, if we were to change the mass of free falling body m, then it should have no effect on the acceleration of free falling body m. And that is true. However, changing the mass of free falling body m would have an effect on the acceleration of body M. And that would cause a change in the free fall time.
Keep in mind that the accelerations mentioned above are relative to the center of mass of the two bodies, NOT the relative acceleration. This is sometimes a source of misunderstandings in this type of discussion.
  • #35
Handy test objects could be Planets? Any discrepancy between the two masses would / could be revealed in the details of their orbits, perhaps.
  • · Replies 125 ·
  • · Replies 41 ·
12K
12K
