Time period of a heavy spring with an attached mass at the end
The discussion focuses on deriving the time period equation for a spring-mass system while accounting for the mass of the spring, specifically avoiding energy analysis methods. The user seeks a method similar to the derivation for a massless spring, emphasizing the need for uniform mass distribution along the spring's length. Key insights include the boundary condition changes introduced by the mass at the end and the approximation involving the factor m/3, where m represents the spring's mass. This approximation assumes the spring's mass is negligible enough not to significantly alter the system's vibrating shape.
  • Understanding of harmonic motion principles
  • Familiarity with spring constants and Hooke's Law
  • Basic knowledge of differential equations
  • Concept of boundary conditions in mechanical systems
  • Research the derivation of the time period for a spring-mass system with mass included
  • Study the effects of boundary conditions on oscillatory systems
  • Explore the mathematical treatment of longitudinal wave equations
  • Investigate the implications of the m/3 approximation in spring dynamics
Physics students, mechanical engineers, and anyone studying oscillatory systems or spring dynamics will benefit from this discussion.
thephysicist
I want to know the way to derive the time period equation of a spring mass system accounting for the mass of the spring but not using the energy analysis method but by proceeding in the same way as we do by ignoring the mass of the spring. Please help. I did not find any texts at my level. Any links would suffice gratefully.
What assumptions are you making about the distribution of mass along the length of the spring?
Uniformly distributed.
I did a Google search on "mass on heavy spring" and found loads of hits. I am not sure what your level is but how does this link suit you (it was top of my list)?
Thanks for the link but this derivation also uses energy analysis. I want to find an approach that is similar to deriving the equation of motion of a massless spring with an attached mass.
The equations of motion for the spring without an extra mass on the end are basically the same derivation as the wave equations for longitudinal waves (not transverse waves in a string under tension).
The mass on the end just changes the boundary conditions at the end.
You will find plenty of references to an approximate solution that includes m/3, where m is the mass of the spring. The approximations is to assumes the spring mass is small enough not to affect the vibrating shape of the spring. That seems to be what sophiecentaur's reference is doing, but it just states the m/3 factor without attempting to justify it.
  • · Replies 20 ·
  • · Replies 131 ·
