Time travel is posibble or not ?
ngkamsengpeter
Since theory of relativity predit time dilation effects . So does it mean that we can travel backwards or forward in time ?
No. It merely illustrates the concept is illogical. Travelling back in time is conceptually flawed. Strictly speaking, the atoms that compose your body would have to return to the position they occupied in the past [not to mention the atoms that compose your 'time machine'.] Otherwise, you would violate causality - the atoms composing you and your time machine would literally be in two different places at the same time! That, at best, is a logical impossibility.
That argument doesn't make sense in terms of the spacetime viewpoint--the atoms that compose your body don't have to rearrange themselves into an earlier state, rather they just have to move to the region of spacetime where the earlier versions of themselves still were in that state, so the older version of you can interact with the younger version. Think of a block of solid ice with various 1-dimensional strings embedded in it--if you cross-section this block, you will see a collection of 0-dimensional points (the strings in cross-section) arranged in various positions on a 2-dimensional surface, and if you take pictures of successive cross-sections and arrange them into a movie, you will see the points moving around continuously relative to one another (in terms of this metaphor, the idea that different frames define simultaneity differently means you have a choice of what angle to slice the ice when you make your series of cross-sections). You shouldn't think of time travel as the points returning to precisely the same configuration they had been in at an earlier frame of the movie; instead, you should just imagine one of the strings curving around into a loop within the 3-dimensional block.
Time travel is allowed by general relativity in certain circumstances--the technical term used is "closed timelike curves"--so unless you think GR contains a logical contradiction, there can't be any logical inconsistency in the idea of backwards time travel. Of course, most physicists would probably bet that closed timelike curves, like singularities, will be eliminated by quantum gravity, but it's not clear that they will be yet, and a number of physicists (Kip Thorne, for example) take time travel to be a real possibility (in the sense of being allowed by the laws of physics, not in the sense of something we'd be able to do in the forseeable future).
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
