Tips for Solving the Doomsday Equation
  • Thread starter Thread starter Laxer42
17 replies · 3K views
Laxer42
Solve the “Doomsday equation”
dN/dt = N^α
and show that for α > 1, the solutions approach a vertical asymptote in finite time. What happens for α < 1?
n/a
dN/dt = N^α
int(N^-a)=int(dt)
[N^(1-a)]/[1-a]+c=tI believe this is a solution, but it does not produce the results I am told to be looking for.
Orodruin said:
Did you try solving for N?
Yes. I didn't think that helped though.
Orodruin said:
It also does not help that you do not tell us what you got.
Thanks for being nice about it.
N=(t-at)^(1/(1-a))
Laxer42 said:
N=(t-at)^(1/(1-a))
What happened to the integration constant?
You are welcome for having a stranger trying to help you for free. The least you can do when asking people to help you for free is to make it easier for those people to help you. If you just say "it did not help me" you are not furthering your own cause.
Orodruin said:
What happened to the integration constant?You are welcome for having a stranger trying to help you for free. The least you can do when asking people to help you for free is to make it easier for those people to help you. If you just say "it did not help me" you are not furthering your own cause.
I assumed the constant was equal to zero.
If you want to be rude because I've made honest mistakes, I don't think your help will be productive for either of us.
  • Skeptical
You cannot arbitrarily set integration constants to zero. What do you get if you do not assume this?
Your problem here is your own arrogance, not me being rude. You are the one who wrongly interpreted a factual statement about the process (it does not help your learning process to keep people trying to help you in the dark regarding what you have done so far) for rudeness and decided to respond with a snarky remark.
FYI, people helping here generally know the answer but nobody here believes in just providing answers. We will want you to show your effort and we will help guide your thinking. We believe this is much more beneficial to you long term. However, in order to help you think, we need to know what you have bern thinking so far and you have been very reluctant in providing this information. It took me two additional points to get information from you that should have been provided in the OP. I am sure your mistakes are honest and I have no problem with that. What I do have a problem with is the impression you give of somehow being offended when I have been asking questions about your progress that we have no way of knowing unless you provide it.
Had you actually provided all the necessary information in your OP, this thread would have been over by now.
How exactly should someone correct your mistakes without being seen as rude?
"Did you solve for N?"
"Yes. I didn't think that helped though."
"Well show me what you got anyway."
"By the way, in the future you should make sure to show any and all work you have done regardless of whether you think it's right or even relevant. It usually speeds things along."
N=(t-at)^(1/(1-a))+c
The constant appears correctly in your original post. If you solve for N, it will not be the same thing as first solving for N with the constant equal to zero and then adding a constant. I suggest you rename the constant ##t_0## and put it on the other side of the equation. If that does not help, please show us each step of when you solve for N.
N=[(t-##t_0##)(1-α)]^(1/(1-α))
Orodruin said:
Right, but for ##\alpha > 1## I would introduce a new constant ##\beta = \alpha -1 > 0## to tidy things up. What can you then observe as ##t\to t_0##?
N=[-(t-##t_0##)(B)]^(1/(1-α))
It would go to zero as ##t\to t_0##
Laxer42 said:
So N=[-(t-##t_0##)(##\beta )]^(1/(1-α))##
Would it? Introduce ##\beta## in the exponent too and remember that ##\beta > 0## so also ##1/\beta > 0##. I also suggest writing ##-(t-t_0)\beta## as ##\beta(t_0-t)## (the relevant times for the finite solution are ##t < t_0##).
So let me tell you how that comes through when you do not provide your actual work:
"Yes, of course I did, why are you not helping?"
The better way (faster and more informative) would have been:
"Yes. I got X. I did not think it helped because Y"
Again, how you expect people to be able to help you without providing your actual work is beyond me and it is also against forum rules. You provided your actual work up until ##N^{1-\alpha}/(1-\alpha) + t_0 = t## so naturally the next question is about whether you tried to solve for ##N## or not. If you did you should then provide your work. It is not strange that people become irritated with you when they have to drag information out of you over the course of several posts rather than getting straight to the point.
This should not even need pointing out to you. It is quite obvious that we cannot help you unless we do not undertand where your problem lies. Try to imagine how things seem from the other side.
None of those remarks are rude; they are meant to be helpful, and you would find them to be so if you were less defensive and more willing to work with helpers.
