What is the relationship between tire physics and slip angle?
The slip angle is the angle between the direction a tire is pointing and the actual direction of travel during cornering. It plays a crucial role in vehicle dynamics, affecting handling characteristics such as understeer and oversteer. A greater front wheel slip angle compared to the rear leads to understeer, while a greater rear wheel slip angle results in oversteer. Understanding slip angle is essential for optimizing tire performance and vehicle control, particularly in motorsports.
  • Understanding of tire mechanics and rubber properties
  • Familiarity with vehicle dynamics concepts
  • Knowledge of cornering behavior in vehicles
  • Basic grasp of suspension systems in race cars
  • Research "tire slip angle effects on vehicle handling"
  • Study "understeer vs. oversteer in motorsport"
  • Explore "tire tread design and its impact on performance"
  • Learn about "vehicle dynamics simulation tools"
Automotive engineers, motorsport enthusiasts, race car drivers, and anyone interested in enhancing vehicle performance through tire dynamics.
fog37
Hello everyone,
Does anyone know what the slip angle is in relation to rubber tires? What is its effect? Is it a positive or negative effect?
My basic understanding is that when a tire is cornering, the tire does not point directly along the curved direction of motion but is slightly twisted, since it is made of rubber, and points slightly towards the outside of the curve...
Have you Googled "Tyre Slip Angle" yet".
fog37 said:
Hello everyone,
The tire points inward. The tread distorts as the wheel rolls. The tire must point further in the desired turn direction than the vehicle will actually turn.
yes
What is its effect?
could be good until it goes to bad
positive until it goes to negativeMy basic understanding is that when a tire is cornering, the tire does not point directly along the curved direction of motion but is slightly twisted, since it is made of rubber, and points slightly towards the outside of the curve...
on a motorcycle? which tire?
on a race car are you talking about the right front in a left turn corner or the left front tire in a left turn?
Or are you talking about the rear tires?
i suggest you read race car suspension class ...above...see page 4 post #62
page 12 post # 228
page 24 post # 470 lumpy and the down force
page 41 post # 811 centrifugal vs centripetal
The slip angle is the difference between the direction that a tire is pointing and the direction that it is moving. My experience with it was in simulations that only had to be believable, not necessarily accurate. We modeled it as a lateral (versus tire point direction) force that was a linear function of the slip angle. When the tire points more to the left, the force is to the left.
I assume that a real analysis of turning force would require detailed understanding of the tread design and pattern. It seems that a tire company could more easily set up experimental fixtures than rely on analysis, but I have no authoritative knowledge of that.
I read an ancient book -The Sportscar by Colin Chapman. He explained the relevance of slip angle. When a car is cornering, both front and rear wheels have a slip angle. If the front wheel slip angle is greater than the rear wheel slip angle then you have to steer harder into a corner to go where you want. This is called Understeer and is the safest arrangement but, of course, it reduces the cornering ability - not good for racing and being flash. A 'manoeuvrable' car will have neutral or even Oversteer and the rear wheels will slip more, allowing the back of the car to hang out and, eventually spin. This accounts for the trick which rally drivers use when they use 'reverse lock on the way round a bend fast.
The slip angle is affected, not surprisingly, when power is applied to a wheel; a rear wheel drive car tends to oversteer (we've all been there) and a FWD car tends to understeer, which is more comfortable for the nerves of the passenger.
PS A google search will yield masses of interesting facts about this.
Thanks everyone. All very useful.
I appreciate the Michelin article from cosmik debris. Learning a lot.
  • · Replies 20 ·
  • · Replies 49 ·
13K
