Force Acting on Hinge: 2744 N Torque on Beam Homework: Find Force on Hinge
The discussion centers on calculating the force acting on a hinge for a beam of mass 280 kg and length 2.2 m, supported by a wire at a 30-degree angle. The user seeks clarification on how to adjust their calculations if the beam is raised to a 20-degree angle from the horizontal. Key equations include horizontal and vertical force balances (Fx = 0, Fy = 0) and torque balance (Net torque = 0). The torque from the weight of the beam is expressed as mg * length * cos(theta), highlighting the need to account for the beam's angle in torque calculations.
  • Understanding of static equilibrium principles
  • Familiarity with torque calculations in physics
  • Knowledge of trigonometric functions and their application in force analysis
  • Ability to manipulate and solve equations involving forces and torques
  • Study the effects of angle changes on torque calculations in beam mechanics
  • Learn about the principles of static equilibrium in more complex systems
  • Explore the role of trigonometric functions in resolving forces at angles
  • Investigate real-world applications of hinge forces in structural engineering
Students in physics or engineering courses, particularly those focusing on statics and mechanics, as well as professionals involved in structural analysis and design.
jybe
"A beam of mass M = 280kg and length L = 2.2m is attached to a wall with a hinge (at a 90 degree angle to the wall, sticking out horizontally), and is supported at the other end by a wire making an angle of 30 degrees with the horizontal beam.
What is the force acting on the hinge?"
NOW...this isn't actually what I'm trying to figure out. I'll do the work for the question below, but what I really want to know is how my work would change if the beam was not at a right angle to the wall, but raised up, maybe at an angle of 20 degrees from the horizontal/70 degrees from the wall. Say the wire is now at an angle of 30 degrees from the horizontal but not the beam.
How would I account for the beam's weight in the Fy equation at the start? Would it still be mg?
And in the torque equation, I can't wrap my mind around how it would change, as far as both the wire and beam parts are concerned. If anyone could help me I would really appreciate it
Fx = 0
0 = FHx - Tcos(theta) (Hx is the x compenent of the hinge force)
Fy = 0
0 = FHy + Tsin(theta) - mg
Net torque = 0
0 = Tsin(theta)*L - mg*(L/2)
T = (mg / 2*sin(theta))
[/B]
FHx = Tcos(theta)
FHx = (mg/2sin(theta))*cos(theta)
FHx = 2376.4 N
FHy = mg - Tsin(theta)
FHy = mg - (mg/2sin(theta))*sin(theta)
FHy = 1372 N
FH = √(FHx2 + FHy2)
FH = 2744 N
tan(theta) = (1372/2376.4)
theta = 30 degrees from horizontal
You correctly posted the three statics equations, horizontal balance, vertical balance and torque balance.
Studying the details of those, which terms change if the beam is not horizontal?
I think the FHx changes, and also, I think the torque from the weight of the beam changes, but is it still mg, or is it mg multiplied by an angle? I'm just having a really hard time making sense of what changes and what doesn't.
Anyone?
Sorry for the delay. Sometimes the system doesn't give me an alert when there is a reply.
Yes. How does one determine the torque from a force about a given point?
Its value might change, but not its appearance in the equations.
The torque from the weight of the beam will be mg*length*cos(theta)
But then how do you express the torque on the beam from the wire now?
You have two different angles, no? One for the wire and one for the beam.
9K
  • · Replies 18 ·
14K
