Torque without a torque wrench
  • Level: Undergrad
  • Thread starter Thread starter HRG
    Torque Wrench
3 replies · 8K views · last reply
HRG
I need to tighten the nut for a trailer hitch ball to 250 ft lbs but I don't have a torque wrench that can do it.
I read on a different forum that an alternate old school method to get 450 ft lbs of torque is:
  • Torque = Force x Distance
  • So in that forum's example, have a 180 lb person stand on a 2.5 ft breaker bar. The calculation is 180 x 2.5 = 450.
Is that a correct way to get 450 ft lbs of torque?
If so, then since I weigh 142.3 lbs, 250 ft lbs / 142.3 lbs = 1.76 ft.
0.76 ft is about 9 inches. Therefore 12" + 9" = 21".
So I would have to stand on a breaker bar at 21" from the nut to exert 250 ft lbs of torque.
The breaker bar would of course have to be horizontal while I stand on it for the 250 ft lbs of torque.
Need confirmation from physics gurus whether this is correct or not.
Thanks!
Your math is correct. I would practice my technique before standing on the breaker bar with the nut attached.
You don't want to bounce the bar or have your weight shifting +/- an inch along the bar.
Plan and Practice.
Yes, it's right. Plus what @.Scott said. And you get a +1 for actually properly tightening the hitch ball.
I once designed a threaded connection that needed 3000 ft-lbs of torque. So we bolted a 15 foot length of pipe to the part, attached a deer scale, tied a rope to the deer scale, and had two men pull on the rope until the scale read 200 lbs.
A deer scale is a spring scale used by deer hunters for weighing deer. Like this, but 300 lbs full scale:
Photo of a white hanging spring scale with a red top cap, hooks at each end, and a dial marked in pounds (LB) and kilograms (KG) with a red needle pointer; brand name Pelouze on the front.
We need to close this thread now, since there is liability involved in helping you do something dangerous to save a few bucks. Especially if you are going to be changing trailer balls very often, you should just invest in a new torque wrench. Also, you may want to invest in an extension for that wrench so you can get the nut back off again... :wink:
As a safety tip, since you will likely be turning the hitch 90 degrees in order to be able to use your weight vertically to turn the nut, also put a box or other platform under the part of the wrench where you will be applying your weight, so if you do slip off, you only slip a couple inches onto the box/platform.
