Total acceleration from angular acceleration
7 replies · 4K views
droidofthevoid
A discus thrower ( with arm length of 1.2 m) starts from rest and begins to rotate counterclockwise with a constant angular acceleration of 2.5 [rad/s^2]. What is the magnitude of the total acceleration of the discus when its angular velocity is 9.0[rad/s]?
I'm not really connecting the dots here. Do I treat the discus thrower as a rigid body and give a simple moment of inertia, which I then plug into a torque equation tau = I alpha?
Not necessary. The question is interested in the acceleration of the discus, so there is only a need to consider the motion of the discus.
So then I treat it as a particle going in a circle and use a = R alpha? Do I neglect the omega= 3.0 rad/s?
Yes in this case you can treat it as a particle going round in a circle. ##a = r\alpha## will give you what kind of acceleration? As a hint, see the comment below as well.
omega= 3.0 rad/s?
You mean 9rad/s? No you do not ignore this.
It'll give tangential acceleration
Yes, the question wants the total acceleration, so that should give you a clue that it is not just tangential acceleration at play here. What else?
Well then, I would presume it would have something to do with torque and perhaps treating the thrower as a rigid body? or radial acceleration, which would be omega squared times r.
Torque by the thrower is the cause for the tangential acceleration/angular acceleration of the discus. And as mentioned above, the thrower himself need not be considered in this problem.
The discus is traveling in a circular motion, yes? Tangential acceleration is not sufficient to ensure that the discus is traveling in a circular motion, uniform or not. What about considering the radial acceleration?
