This will work for all six sides of the cube.
  • Thread starter Thread starter hils0005
    Cube Flux
The discussion focuses on calculating the total flux of the vector field F(x,y,z) = 8x²y i + 6yz² j + y³z k through a cube defined by its vertices. The surface integral is set up using the general flux formula Φ = ∫∫ F ⋅ n dS, where n is the unit normal vector. The user initially attempts to compute the flux using a specific surface setup but encounters issues with the normal vectors on certain cube faces. The recommendation is to apply the general flux formula for accurate results across all six sides of the cube.
  • Understanding of vector calculus and surface integrals
  • Familiarity with the divergence theorem
  • Knowledge of normal vectors in three-dimensional space
  • Proficiency in evaluating double integrals
  • Study the divergence theorem and its applications in flux calculations
  • Learn about unit normal vectors and their significance in surface integrals
  • Practice evaluating double integrals over various surfaces
  • Explore advanced vector calculus topics, such as Stokes' theorem
Students and professionals in mathematics, physics, and engineering who are working on vector calculus problems, particularly those involving flux calculations through three-dimensional surfaces.
hils0005
Calculate the total flux of vectorF(x,y,z)=8x^2y i + 6yz^2 j + y^3z k outward through the cube whose verticies are(0,0,0), (1,0,0), (1,1,0), (0,1,0), (0,0,1), (1,0,1),(1,1,1), (0,1,1).
\int\int \widehat{}F \bullet (-partial z/dx i -partial z/dy j + k) dxdy
I set up the surface S: xyz\leq 1
so z \leq 1/xy
dz/dx= 1/y lnx
dz/dy= 1/x lny
so F (dot) (-dz/dz i -dz/dy j + k)
=-8x^2lnx - (6yz^2lny)/x + y^3z
I then plugged in z
=-8x^2lnx - 6lny/x^3y + y^2/x
\int\int =-8x^2lnx - 6lny/x^3y + y^2/x dxdy
0 \leq x \leq 1
0 \leq y \leq 1
Does this look correct?
Your formula there should work for the top and bottom faces of the cube. But your front/back, left/right sides might pose problems, because their normal vectors don't have a k component.
I think you might want to consider using the general flux formula:
\Phi=\int\int \vec{F}\circ\hat{n}dS, where \hat{n}dS is the unit normal vector of the surface times the differential area (i.e. dx dy, dy dz, etc).
