Total Force on Wire: Solving a Physics Problem
1 reply · 8K views · last reply
Fisicks
A stiff wire 50cm long is bent at a right angle in the middle. One section lies along the z axis and the other is along the line y=2x in the xy plane. A current of 20A flows in the wire down the z axis and out the line in the xy plane. The wire passes through a uniform magnetic field give by B=.318i. Determine the magnitude and direction of the total force on the wire.
F=BILsin(theta)
For the z axis part of the wire, I get F=(20)(.25)(.318)
For the xy plane part of the wire I get (20)(.25)(.318)(.447)
Now when i square these forces take the sum and square root the answer, I don't get the magnitude I should. This problem is pretty straight forward, not quite sure why I can't get it.
Thanks guys
0.447 ≈ cos(θ), where θ is the angle the xy-plane portion of the wire makes with the x-axis (also the direction of the B field.
sin(θ) = 2/√(5) .
