Total mass of a cord, uniform density
The discussion focuses on calculating the total mass of a cord with uniform density, specifically using the formula mass = L times integral of density. Participants emphasize the need to determine the arc length from -5 to 5 and multiply it by the constant density, defined in kg/m. The hint provided suggests using the differential arc length formula dS² = dx² + dy² to facilitate the integration process. The approach involves breaking the cord into infinitesimal segments for accurate mass computation.
  • Understanding of integral calculus
  • Familiarity with line integrals
  • Knowledge of arc length calculation
  • Basic concepts of uniform density
  • Study the application of line integrals in physics
  • Learn how to compute arc length in parametric equations
  • Explore the concept of differential elements in calculus
  • Review examples of mass calculations for variable density objects
Students in physics or engineering courses, particularly those tackling problems related to mass distribution and integration techniques.
RedAnsar
http://i54.tinypic.com/2uztu6d.jpg
I don't know how to use LaTeX, sorry...
mass = L times integral of density, where the endpoints are the bounds of the region.
However, in this case...it seems to me that things are reserved...
I just really don't understand. I thought perhaps I should try and integrate the position function, but...well, that's sort of trivial, and I'm supposed to get an integral in the form of the hint, so that's definitely not the right way to think about it...the density is constant, so I guess I need to break up the cord into little pieces, and integrate that, I guess using parametrization? A line integral??
Sorry for the ridiculous question,
RedAnsar
Wouldn't you need to get the arc length from -5 to 5 and then multiply that by the density?
RedAnsar
The density here is defined as kg/m
so it would make sense that you find the cord length and multiply by density to obtain mass.
Hint : dS**2=dx**2 + dy**2
  • · Replies 19 ·
14K
