Trace distance between two probability distributions - prove
Emil_M
Let ##\{p_x\}## and ##\{q_x\}## be two probability distributions over the same index set ##\{x\}={1,2,...,N}##. Then, the trace distance between them is given by ##D(p_x,q_x):=\frac{1}{2} \sum_x |p_x-q_x|##.
Prove that ##D(p_x,q,_x)=max_S |p(S)-q(S)|=max_S | \sum_{x \in S} p_x - \sum_{x \in S} q_x|##, where the maximization is over all subsets ##S## of the index set ##\{x\}##.
See above
[itex] \begin{align*}<br /> \frac{1}{2} \sum_x |p_x-q_x| &\geq | \sum_{x \in S} p_x - \sum_{x \in S} q_x|\\<br /> &= |\sum_{x \in S} p_x-q_x|<br /> \end{align*}[/itex]
Then, I have tried playing around with the triangle inequality, but that didn't go anywhere...
Thanks for you help!
The key piece of information here is that all the probabilities will sum to 1.
If p(1) - q(1) = z, then the sum of q(2) to q(N) minus the sum of p(2) to p(N) will also be z.
See above
If you let ##p_x - q_x = r_x##, the ##r_x## sum to zero. We can re-write ##D(p_x,q_x)## as ##(1/2) \sum_x |r_x| ## and ##p(S) - q(S) = \sum_{x \in S} r_x##.
We can write
[tex]\sum_{x \in S} r_x = \underbrace{\sum_{x \in S, r_x > 0} r_x }_ {\geq 0} +<br /> \underbrace{\sum_{x \in S, r_x < 0} r_x }_ {\leq 0}[/tex]
Think about what properties ##S## must have in order that the absolute value of the above sum be maximal, say at the subset ##S = S_0##.
