Transformer Radiator Design and Calculations
The discussion centers on calculating the delta T (temperature difference) for oil in a transformer radiator system designed by Izak Nel. Key parameters for the calculation include the surface area of radiator fins, thermal conductivity, specific heat capacities of materials, ambient temperature, flow rates of oil and air, kVA output, and I2R losses. Participants emphasize the complexity of these calculations, suggesting that simulations are often used by manufacturers. They recommend testing the system under operational conditions and refer to essential literature for further understanding.
  • Understanding of thermal conductivity and specific heat capacity
  • Familiarity with transformer operation and cooling methods, specifically ONAN and OFAF
  • Knowledge of fluid dynamics and heat transfer principles
  • Experience with empirical calculations in thermal systems
  • Study "Cooling of Electronic Equipment" by Allan W. Scott for temperature calculation methodologies
  • Read "Transformer Engineering" by Blume, Boyajian, Camilli for transformer design insights
  • Explore dynamic fluid flow analysis techniques for thermal management
  • Research simulation tools used in thermal analysis for transformer systems
Electrical engineers, transformer designers, and technicians involved in thermal management and cooling system design for transformers will benefit from this discussion.
Izak_Nel
Hey guys
I'm BRAND SPANKING new to posting anything an any forum ever...this is a last resort at the end of much research, brainstorming and desperate googling...
My problem:
We've built a transformer tank to house the core and this will be filled with oil, a radiator was built as well - I have to do thermal prediction calculations and am at a complete loss...
I now have to calculate:
At a known flow-rate of forced oil through the radiator, and a known volume of air forced over the radiator - What delta T can be expected between oil entering the radiator and oil leaving the radiator
I can measure/obtain the following parameters:
1. Surface area of radiator fins - individual and cumulative.
2. Thermal conductivity of fin material, air and oil.
3. Specific heat capacity of fin material, air and oil.
4. Ambient temperature of forced air.
5. Flow-rates of both oil and air.
6. kVA Output of the transformer
7. I2R Losses of transformer
8. Desired steady state temperature of oil therefore also the maximum allowable delta-T
Is there a way by using these parameters as well as others needed that I may not have thought of to calculate the Delta-T of oil through the radiator ?
Help would be GREATLY appreciated
Greetings from South Africa
Izak Nel
Hello Izak: Welcome - these are not trivial calculations, in fact most suppliers use simulations exclusively - Also keep in mind a dynamic fluid flow analysis for the internals to ensure there are no unacceptable hot spots on the windings or core.
The manufacturers today have 100 years of designs, experience, knowledge and hard lessons.
The ONLY way I can see getting into this business - is to buy a business with the entrenched knowledge and tools on hand. You may want to seek out a flexible manufacturer or a consultant.
MLT ? ?
What Windadct said.
Also, it would have been a better idea to do the calcs before you designed the cooling system, not after you already built it.
If you have already built it, why not just test it - and if it starts to overheat, blow more air and/or pump more oil.
AlephZero is correct: If you have already built it, why not just test it - and if it starts to overheat, blow more air and/or pump more oil.
A good book on temperature calculations is
Two good books on transformers are
"Transformer Engineering" by Blume, Boyajian, Camilli...
"Transformers for the Ellectric Power Industry" by Richard L Bean, Nicholas Chackan Jr...
MLT ? ?
I had that feeling sir, was just quietly hoping that i was young, inexperienced and a bit thick and somewhere in all these parameters there must be a reasonably-simplified empirical equation to obtain a ball-park "gut-feel" figure you know ?
AlephZero said:
What Windadct said.
I would have loved to have done calculations before building sir, but i was in the same boat then as i am now - lack of theory, knowledge and experience to calculate anything substantial.
So what I did was:
1. Asses my transformer capacity - 50kVA @ 5773.5A & 5V
2. Evaluate similar transformers with ONAN cooling
3. Copy this design in terms of similar radiator surface areas
4. Re-format configuration from ONAN to OFAF
I will go read up on those books sir, gaining as much knowledge as possible on as many topics and subjects as possible is what makes me grow as a junior technician.
