Why is the resonance condition satisfied in a transverse resonance method?
The Transverse Resonance Method is utilized to determine the propagation constant of waves in waveguides, such as rectangular and dielectric waveguides. This method relies on the presence of standing waves created by reactive loads at both ends of the transmission line, leading to the resonance condition where the input impedances looking in opposite directions are equal in magnitude but opposite in sign. This condition is essential for establishing a resonant structure, as it results in infinite impedance at specific points, effectively creating a standing wave with no power transmission along the line. The physical reasoning behind this resonance condition is tied to the impedance transformation properties of specific line lengths and the nature of terminations at the ends of the line.
  • Understanding of wave propagation in waveguides
  • Familiarity with transmission line theory
  • Knowledge of impedance transformation and Smith Charts
  • Basic concepts of standing waves and resonance
  • Study the principles of wave propagation in rectangular waveguides
  • Learn about impedance transformation using Smith Charts
  • Explore the mathematical derivation of standing wave conditions in transmission lines
  • Investigate the implications of reactive terminations in resonant structures
Electrical engineers, waveguide designers, and researchers in microwave engineering who are focused on wave propagation analysis and resonance phenomena in transmission lines.
EmilyRuck
The Transverse resonance method is used to determine the propagation constant of a wave in several waveguides, like the rectangular waveguide, or also dielectric waveguides.
It takes advantage of the fact that a standing wave is present along a certain direction (transverse with respect to the main propagation direction), due to purely reactive loads at both the ends of the transmission line (which represents the wave propagation). http://www0.egr.uh.edu/courses/ece/ECE6351-5317/SectionJackson/Class%20Notes/Notes%2013%20-%20Transverse%20resonance%20method.pptx provides and example in the slides 3-4-5.
In such conditions, the transmission line (ended with the reactive loads) is said to be a resonant structure. It means that Z_{in}^r (x) looking forward must be equal to minus the Z_{in}^l (x) looking backward, so that Z_{in}^r (x) + Z_{in}^l (x) = 0 for every position x along the line. Why is this the resonance condition? Which is the relation between this condition and the existence of a standing wave?
I tried to consider a transmission line with total length 2 \ell centered in x = 0 and ended at both x = \ell and x = -\ell with a short-circuit Z_L = 0. The input impedance in a generic position x is actually
Z_{in}^l (x) = j Z_0 \tan [ \beta (\ell - |x|)]
Z_{in}^r (x) = j Z_0 \tan [ \beta (-\ell + |x|)] = -j Z_0 \tan [ \beta (\ell - |x|)]
so the assumption Z_{in}^r (x) + Z_{in}^l (x) = 0 seems to be verified. But what is the physical reason for this?
In the linked slides this is derived from the continuity of voltage and current in the position x: V^r = V^l and I^r = -I^l, but this can be applied to every transmission line and for me has apparently nothing to do with resonance.
"In the linked slides this is derived from the continuity of voltage and current in the position x: Vr=Vl and Ir=−Il, but this can be applied to every transmission line and for me has apparently nothing to do with resonance."
Are you sure? For traveling waves, i.e., when the line is terminated at each end in its characteristic impedance Z0, you see Z0 in each direction, that is Zr = Zl = Z0. It seems to me that Zr = -Zl instead produces infinite impedance at the point of interest, making the longitudinal current zero. This is consistent with a standing wave for which no power moves down the line.
Having said that, the concept of "transverse resonance" seems odd to me.
It may be a trivial question, but how can the current be zero? Can you show me the steps?
Yes, it would.
It seems odd to me too, but I have to dig into it :frown:
I take back what I said before about currents, power, etc., after looking at Pozar's book referenced in your link. Here's what I think.
The resonance condition he talks about is transverse to the waveguide axis (you said as much in your post, but I got confused). In the transverse x direction, a rectangular waveguide looks like a parallel plate waveguide with shorts at either end, x=0 and x=a. For the fundamental mode, the waveguide width a corresponds to λ/2. We can evaluate Z looking in either direction by referring to a Smith Chart and reading the reactance off of the outer R=0 circle since you are assuming a lossless structure. For example, consider the left/right impedances at x=a/4, which is λ/8 from one short and 3λ/8 from the other. The Smith Chart shows us that the corresponding reactances are X = 1 and X = -1, so Zleft = 1i, Zright = -1i. Regardless of which x you choose, Z looking left is always the complex conjugate of the right so they always sum to zero. That's how that condition becomes equivalent to a resonant line.
Thank you for having even read that book. I agree with all your considerations and (if you look back to my first post) they are almost equivalent to what I've written about a resonant line and the Z^{left} (x), Z^{right} (x) impedances.
But my question was slightly different: what is the physical reason for a line, having in any position Z^{left} (x) = -Z^{right} (x), to be called a resonant line? Why an adapted line with Z^{left} (x) = Z^{right} (x) = Z_0 is not a resonant line?
The condition Z^{left} (x) = Z^{right} (x) = Z_0 describes a line that is properly terminated at each end, e.g., with a generator and a load each having impedance Z_0 . Such a line supports traveling waves that carry power down the waveguide. The condition Z^{left} (x) = -Z^{right} (x) at every point is special. It can only be set up by the impedance transforming property of specific lengths of line acting on an identical mismatch at each end of the line. The transformation applied to line lengths of x and λ/2-x produces the desired condition, furthermore, only when the mismatch at each end of the line is 0 or infinity (short or open). You can see this from the equations for that transformation, or from the Smith Chart which is a handy graphical tool that solves those equations. The final step is to realize that a transmission line that is open- or short-circuited produces 100% reflections at each end, hence supporting a standing wave mode--in effect a one-dimensional resonant cavity. The fundamental mode occurs at precisely the frequency that produces an exact λ/2 wave between terminations, which is the definition of a resonator.
  • · Replies 18 ·
  • Poll Poll
11K
