Traveling quantum Gaussian wave packet
5 replies · 2K views
boudreaux
Solve the Schrodinger equation and show the probability density is as follows
The Schrodinger equation for a free particle is
$$ih(\partial \Psi/\partial t) = -\frac{\hbar}{2m} \partial^2 \Psi/ \partial x^2$$
Consider an initial state described by the wavefuntion
$$\Psi(x,0) = \sqrt {(\pi_0(x))}exp(iQx)$$
where Q is a constant and $$\pi_0$$ is a normalized gaussian distribution function with zero mean and variance $$(\sigma_0)^2$$
$$\pi_0(x) = (1/\sqrt{(2\pi)\sigma_0})*exp(\frac{-x^2}{ 2(\sigma_0)^2})$$
Solve the schrodinger equation and show that the probability density $$\pi(x,t) = |\Psi(x,t)|^2 $$ at t>0 is given by
$$\pi(x,t) = (1/\sqrt{(2\pi)\sigma(t))}exp( (-\frac{(x-vt)^2) }{ (2\sigma(t)^2) })$$
What are the formulas $$\sigma(t)$$ and v?
Hint: might be easier to use $$\tau = 2m(\sigma_0)^2/\hbar , l = 2Q(\sigma_0)^2 $$
I tried plugging Psi into the right of the Schrödinger equation but can't get anything close to the solution or anything that is usable. How should I solve this?
First, be careful that you are not trying to put ##\Psi(x,0) ## into the Schrödinger equation. That is the ##t=0## boundary condition. You need ##\Psi(x,t)##.
Recall that ##| \Psi |^2 ## means multiply ##\Psi## by its complex conjugate. So that means that the ##\exp (i Q x) ## factor does not appear in ##\pi (x,t)##. It's just a phase, so when you do the abs-square you get 1.
So maybe ##\Psi(x,t) ## can be obtained by the obvious means of putting the ##t## back into the ##\Psi(x,0)## formula?
$$ \Psi(x,t) = \sqrt{\pi(x,t)} \exp(i Q x)$$
This does give you back the correct ##\Psi(x,0) ##. So now, if you put this in the S.E., and turn the crank, you should get something that involves an equation in ##\sigma(t)##. And the ##(t)## part is trying to suggest that it is only a function of time. Meaning the ##x## parts of the S.E. should be identically solved by the form of ##\Psi(x,t)##. Check that is true. If it's not, can you guess what has to be added to ##\Psi(x,t)## to make it true? Remember that ##\pi(x,t)## can't change, so the additional stuff has to be just a phase.
When you struggle through that, you should be able to pull out a functional form for ##\sigma(t)## and a relation between ##v## and ##Q##.
The hint is telling you that the equation might be simpler if you change the time coordinate to the indicated parameter. It may mean that a bunch of the constants in front of the ##\Psi## are cancelled, meaning your equations are a lot easier to write.
boudreaux said:
Homework Statement:: Solve the Schrödinger equation and show the probability density is as follows
Relevant Equations:: The Schrödinger equation for a free particle is
Solve the Schrödinger equation and show that the probability density $$\pi(x,t) = |\Psi(x,t)|^2 $$ at t>0 is given by
How do you solve the Schroedinger equation (SDE) for any potential? What's the general method?
##v## must be related to ##Q## in some way, which you may have to work out as part of the solution. Similarly, ##\sigma(t)## represents the standard deviation of the Gaussian at time ##t##. Note that the solution remains a Gaussian, but its standard deviation changes with time, and this is something else that should come out of your solution.
Note that ##\exp{iQx}## is not a phase factor, as it includes the variable ##x##. Do you know or can you guess what this factor represents? Hint: what does ##v## often represent.
Can you intepret the solution? Before you solve it, it might be useful to see whether you can figure out what the solution means.
This problem, I would say, is less than easy! If you are unsure of what you are doing with the SDE, I suggest you find some less complicated examples before returning to this.
If you do press ahead, get your algebra hat on.
I'd check that expression. I think it should be:$$\pi_0(x) = \frac{1}{\sigma_0\sqrt{2\pi}}\exp(\frac{-x^2}{ 2(\sigma_0)^2})$$
