Travelling to a Star 40 Light Years Away: Time and Distance Calculations
The problem involves calculating the distance and time associated with traveling to a star that is 40 light years away, specifically considering relativistic effects such as length contraction and time dilation. The subject area includes concepts from special relativity and kinematics.
  • Participants discuss converting light years to meters to establish a rest length and then applying length contraction to find the distance as perceived from a spaceship. They also consider using the velocity equation to determine the time experienced by the traveler.
There is an ongoing exploration of the problem with participants providing guidance on relevant concepts like length contraction and suggesting approaches to calculate time and distance. Multiple interpretations of the problem setup are being discussed, particularly regarding how to apply relativistic principles.
Participants are working within the constraints of a homework assignment, which may limit the information they can provide or the methods they can use. There is an emphasis on understanding rather than simply arriving at a solution.
usahockey7
A star is 40 light years from Earth.
(a) How far would you measure this distance to be if you traveled it in a spaceship moving at 1.00X10^8 m/s
(b) How long would the trip last (for you)?
Can someone please help me out with this question and what equations I should use to solve this, thanks in advance
Look up length contraction, this should be a fairly simple question.
okay so for part a, convert light years into meters and that will be the rest length or the distance observed by someone from Earth and then I need to solve for the relativistic length of the distance observed from someone in the spaceship?
And then for part b, use the rest length I calculated in part a, and use the velocity equation v = d/t and solve for the time, which in this case would be the time it would take the space shuttle to reach the star observed by someone on Earth and use that to find the time that the person in the space shuttle would experience?
Yes. It would be shorter, of course.
Sure, but the more direct approach is using the contracted length from part a) and the fact that you know what speed the ship is traveling at, and immediately solve for the time you see as someone on the ship.
Perfect, thanks for helping and explaining this rather than just giving me an answer.
  • · Replies 21 ·
