Trig work problem (am I correct?)
7 replies · 2K views
Miike012
Trig work problem... (am I correct?)
If we call the height @ which the supports cross ,x, express this height as an equation in terms of H1 and H2 Only... Use similar triangle...
Are my proportion correct?
x/H1 = (L1-L)/L1
x/H2 = (L)/L1 = (L1-L)/L1
Because Where the two lines intersect you can see that the two angles are congruent (If I did it correctly)
Thus L1-L = L
And Are my congruent angles in my picture correct?
Thus L1-L = L
(try using the X2 icon just above the Reply box :wink:)
No, that's obviously not correct … you're saying L is always half of L1, which it isn't. :redface:
x/H1 = (L1-L)/L1
Correct :smile:, but it'll be easier if you rewrite it …
x/H1 = 1 - L/L1
x/H2 = L/L1
carry on from there :wink:
No, that's obviously not correct … you're saying L is always half of L1, which it isn't. :redface:Correct :smile:, but it'll be easier if you rewrite it …
x/H1 = 1 - L/L1
x/H2 = L/L1
The segment starting from the right starting @ H2 going towards line x has to be the same length as the line segment L1 to x... because isn't line x is a angle bisector...
Thus segment L1-L must equal segment L...?
I see what you are saying but I guess I am confused.. I am just learning geometry so maybe you can help my understand because it states that if an ray bisects an angle.. the ray creates two congruent angles... and a point on the angle bisector is equal distance from the sides of the angle...
So my angles that I say are equal are incorrect?
If you can.. can u show me which ones are equal?
