Trignometric Substiution Problem
  • Thread starter Thread starter Archimedes II
8 replies · 2K views
Archimedes II
[itex]\displaystyle \int _0 ^a 4x^2 \sqrt{a^2-x^2} dx[/itex]
[itex]\cos^2 x =1 - \sin^2 x[/itex]
Substuting
Substituting [itex]x=a \sin(\theta)[/itex]
[itex]dx=a\cos( \theta) d\theta[/itex]
x=0
asin[itex]\theta[/itex]=0
[itex]\displaystyle \int_{0}^{a} 4x^2 \sqrt{a^2-x^2} dx =[/itex]
[itex]\displaystyle \int_{0}^{\pi/2} 4(a\sin\theta)^2 \sqrt{a^2-(a\sin\theta)^2} a\cos\theta d\theta=[/itex]
[itex]\displaystyle \int_{0}^{\pi/2} 4a^2sin^2\theta \sqrt{a^2-a^2sin^2\theta}a\cos\theta d\theta=[/itex]
[itex]\displaystyle \int_{0}^{\pi/2} 4a^2sin^2\theta a \sqrt{1-sin^2\theta}a\cos\theta d\theta=[/itex]
[itex]\displaystyle \int_{0}^{\pi/2} 4a^2sin^2\theta a cos\theta a\cos\theta d\theta=[/itex]
[itex]\displaystyle 4a^4\int_{0}^{\pi/2} sin \theta cos^2 \theta d\theta=[/itex]
U substitution
[itex]u=cos\theta[/itex]
[itex]-du= sin\theta d\theta[/itex]
[itex]\displaystyle 4a^4\int u^2 du=[/itex]
When I put in the bounds it yields from 1 to 0. What did I do wrong
So the code is messed up basically
Integral from 0 to a [4x^2 squareroot(a^2 - x^2)]dx =
4a^4 integral from 0 to pi/2 [sin theta cos^2 theta] dtheta
I'm stuck trying to change the bounds with a u substitution
New Bounds
x=a
a sin[itex]\theta[/itex]=a
sin[itex]\theta[/itex]=1
[itex]\theta[/itex]=[itex]\pi[/itex]/2x=0
[itex]\displaystyle \int_{0}^{\pi/2} 4(a\sin\theta)^2 \sqrt{a^2-(a\sin\theta)^2}\ \, a\cos\theta d\theta=[/itex]
I fixed your LaTeX code up to this point.
[itex]\int from 0 to \pi/2 4(a^2sin^2\theta)\sgrt{a^2-(a^2sin^2\theta)} acos\theta d\theta[/itex]=
[itex]\int from 0 to \pi/2 4(a^2sin^2\theta) a \sgrt{(1- sin\theta)} acos\theta d\theta[/itex]=
[itex]\int from 0 to \pi/2 4(a^2sin^2\theta) a sos\theta acos\theta d\theta[/itex]=
[itex]4a^4\int form 0 to \pi/2 sin \theta cos^2 \theta d\theta[/itex]
Let u= [itex]cos/theta[/itex]
thus -du=[itex]sin/theta d\theta[/itex]
My problems is when I set the new bounds I get from 1 to 0 not 0 to 1. What am I doing wrong?
Here is the Code for some of the lines I fixed:
Code:
The "\displaystyle" modifier allows the integral symbol to be larger than otherwise.
I'll let you edit the Original Post .
Ok, I fixed it thank you very much. I didn't know how to put a bound into the intergral code.
U substitution
So you get
[itex]\displaystyle -4a^4\int_{1}^{0} u^2\,du[/itex]
Right?
SammyS said:
So you get
Right?
Yes but the how can the bound be from a higher number to a smaller one.
What does switching the order do to the integral?
I solved it I forgot to square the sin at the end. I did't need to use a u substitution.
Any regardless if you have that bound it yields a negative answer.
Thanks for helping though.
The answer is
[itex]\pi a^4/4[/itex]
Archimedes II said:
I solved it I forgot to square the sin at the end. I didn't need to use a u substitution.
The answer is
Yes. It works out just fine either way.
Switching the limits of integration switches the sign. That's good because it got rid of that leading negative sign.
... and you learned a bit more of LaTeX coding .
