Trignometric Substiution Problem
  • Thread starter Thread starter Archimedes II
Archimedes II
\displaystyle \int _0 ^a 4x^2 \sqrt{a^2-x^2} dx
\cos^2 x =1 - \sin^2 x
Substuting
Substituting x=a \sin(\theta)
dx=a\cos( \theta) d\theta
x=0
asin\theta=0
sin\theta=0
\theta=0
\displaystyle \int_{0}^{a} 4x^2 \sqrt{a^2-x^2} dx =
\displaystyle \int_{0}^{\pi/2} 4(a\sin\theta)^2 \sqrt{a^2-(a\sin\theta)^2} a\cos\theta d\theta=
\displaystyle \int_{0}^{\pi/2} 4a^2sin^2\theta \sqrt{a^2-a^2sin^2\theta}a\cos\theta d\theta=
\displaystyle \int_{0}^{\pi/2} 4a^2sin^2\theta a \sqrt{1-sin^2\theta}a\cos\theta d\theta=
\displaystyle \int_{0}^{\pi/2} 4a^2sin^2\theta a cos\theta a\cos\theta d\theta=
\displaystyle 4a^4\int_{0}^{\pi/2} sin \theta cos^2 \theta d\theta=
U substitution
u=cos\theta
-du= sin\theta d\theta
\displaystyle 4a^4\int u^2 du=
When I put in the bounds it yields from 1 to 0. What did I do wrong
So the code is messed up basically
Integral from 0 to a [4x^2 squareroot(a^2 - x^2)]dx =
4a^4 integral from 0 to pi/2 [sin theta cos^2 theta] dtheta
I'm stuck trying to change the bounds with a u substitution
New Bounds
x=a
a sin\theta=a
sin\theta=1
\theta=\pi/2x=0
asin\theta=0
sin\theta=0
\theta=0
\displaystyle \int_{0}^{\pi/2} 4(a\sin\theta)^2 \sqrt{a^2-(a\sin\theta)^2}\ \, a\cos\theta d\theta=
I fixed your LaTeX code up to this point.
\int from 0 to \pi/2 4(a^2sin^2\theta)\sgrt{a^2-(a^2sin^2\theta)} acos\theta d\theta=
\int from 0 to \pi/2 4(a^2sin^2\theta) a \sgrt{(1- sin\theta)} acos\theta d\theta=
\int from 0 to \pi/2 4(a^2sin^2\theta) a sos\theta acos\theta d\theta=
4a^4\int form 0 to \pi/2 sin \theta cos^2 \theta d\theta
Let u= cos/theta
thus -du=sin/theta d\theta
My problems is when I set the new bounds I get from 1 to 0 not 0 to 1. What am I doing wrong?
Here is the Code for some of the lines I fixed:
Code:
[itex]\displaystyle \int_{0}^{a} 4x^2 \sqrt{a^2-x^2} dx =[/itex]
[itex]\displaystyle \int_{0}^{\pi/2}  4(a\sin\theta)^2 \sqrt{a^2-(a\sin\theta)^2} a\cos\theta d\theta=[/itex]
The "\displaystyle" modifier allows the integral symbol to be larger than otherwise.
I'll let you edit the Original Post .
Ok, I fixed it thank you very much. I didn't know how to put a bound into the intergral code.
U substitution
u=cos\theta
So you get
\displaystyle -4a^4\int_{1}^{0} u^2\,du
Right?
SammyS said:
So you get
Right?
Yes but the how can the bound be from a higher number to a smaller one.
What does switching the order do to the integral?
I solved it I forgot to square the sin at the end. I did't need to use a u substitution.
Any regardless if you have that bound it yields a negative answer.
Thanks for helping though.
The answer is
\pi a^4/4
Archimedes II said:
I solved it I forgot to square the sin at the end. I didn't need to use a u substitution.
The answer is
\pi a^4/4
Yes. It works out just fine either way.
Switching the limits of integration switches the sign. That's good because it got rid of that leading negative sign.
... and you learned a bit more of LaTeX coding .
