Trigonometry: Analyzing and Graphing a Cosine Function
13 replies · 2K views
EddieLP
Hey I need a second opinion to see if my formulas and calculations are correct. Also I need help with graphing this problem.
My problem is to find amplitude, period, horizontal shift, vertical translation, step and then graph of:
y= 2 - (1/3) cos ( πx + (3π/2) ) , -1/4 ≤ x ≤ 15/4
Using the formula:
y = A cos ( Bx + C) + D
A = 2
B = π
C = 3/2
D = 0
Amplitude: |A| = 1/3
Period: ((2π) / |B|) = 2
Horizontal Shift: -C/B = (3/(2π))
Vertical Translation: D = 0
Step: ((2π)/2)/B = 1
Mathematics news on Phys.org
All of your data results appear to be correct.
Mod edit: Some of the results are incorrect.
What is the problem you are having with the graph?
JBA said:
All of your data results appear to be correct. What is the problem you are having with the graph?
I'm lost on what goes where on the graph.
Do you know the general shape of a simple y=cos x curve?
What method are you using to try to create this curve?
Actually, upon review I have realized that your A = 2 and D = 0 values are in error but your amplitude is correct. Look at all of the equation modifiers again to see if you can identify the correct values for A & D
Also review your C/B value with respect to π
Using the formula:
A = 2
B = π
C = 3/2
D = 0
A is not 2 and D is not 0.
Your amplitude and period are correct, but the horizontal shift and vertical translation are incorrect. I don't know what "step" means with regard to this problem. Is "step" half a period?
Horizontal Shift: -C/B = - (3/(2π))
I've made adjustments to Horizontal Shift by making it a negative number
I put Vertical translation as 0 since there is no D in the problem.
I'm not sure what step is but our teacher told us the formula for it.
Is there something I am missing to find Vertical translation?
Is there another name for "Step"?
The formulas that were given to me for step are different for each function. Sin and Cos is: ((2π)/2)/B, Tan is (π/2)/B
OK, your problem is thinking that D must be at the end of the equation. Reverse the equation order and see what that makes the value of D be.
No, that's still wrong.
Still wrong.
What is B? What is C?
Yes, there is.
This is because the period of the basic, untransformed sine and cosine functions is ##2\pi##. The period for the basic tangent function is ##\pi##.
I reversed the order and got 2!
So Vertical Translation = 2
Still wrong.
I found B and C by factoring out p from:
factored form:
y= 2 - (1/3) cos ( π ( x + (3/2) )
from the formula: y = A cos ( Bx + C) + D
B = π
C = 3/2
Formula for Horizontal Shift is - ( C / B )
(3/2)/(π/1) = 3/(2π)
I'm trying to find out what's missing, still trying to find. any hints?
Yes
factored form:
B = π
C = 3/2
No, the pattern in your formula is different.
Formula: y = A cos(Bx + C)
In your work, you factored out ##\pi## from both terms
The formula is NOT A cos(B(x + C))
This formula, which you are blindly applying, is for the equation y = A cos (Bx + C)
From this formula, what is B and what is C?
The vertical shift is 2; so now you have everything except a confirmed horizontal shift.
Actually, you have to think in terms of radians, the simple answer is that C = 3π/2 = 1.5π = 270° such that when x = 0 then cos (0 + 270°) = -1 and with the vertical y offset = 2 the result is 2 -1 = 1 (the minimum height of the oscillation) and when x = .5 then cos (.5 + 1.5)π = 2π = cos 180° =0 and y = 2+0 = 2 (the centerline of the curve oscillation) and when x = 1, cos ( 1 +1.5)π = cos 2.5 = cos 90° = 1 and y = 2+1 = 3 ( the maximum height of the oscillation), etc
One clarification on the above, all of the above max/ min values of 1 & -1 are before muliplying the results of the cos by 1/3 as required by the total equation so for the purposes of your calculations and graph the results are actually 2 - 1/3 x 1 = 1.666, 2 - 1/3 x 0 = 2 and 2 - 1/3 X -1 = 2 + 1/3 = 2.333.
Mark44 said:
Yes
B = πx
C = 3π/2
Horizontal Shift = -(3/2)!
My book says that I have to factor out the coefficient of π before finding amplitude, period, etc.
