Trigonometry differentiation problem
bryansonex
Differentiate the following
[tex]cos^2 x[/tex]
[tex] <br /> \frac{d(cos^2 x)}{dx}<br /> <br /> = 2 (-sin^{2-1} x).\frac{dx}{dx}<br /> <br /> = 2 (-sin x).1<br /> <br /> = -2 sin x<br /> [/tex]
But the answer given is-
[tex] -2 cos x sin x[/tex]
Can you please tell me what's wrong !
You should be more careful in applying the chain rule. There are many formulations, the way I prefer it is to let u = cos(x). Then you are asked for d(u2(x))/dx. According to the chain rule, this is
[tex]\frac{d}{dx} u(x)^2 = \frac{d(u^2)}{du} \cdot \frac{du}{dx}[/tex]
The first factor is 2u = 2 sin(x), but then you need to multiply du/dx, not dx/dx.
Or another rule of thumb which I prefer is to always take the derivative of what's inside... I'll show you what I mean:
If we are to take the derivative of [itex]x^n[/itex] we get [itex]nx^{n-1}[/itex]
but behind the scenes you're also taking the derivative of x, but since this is 1, multiplying by 1 doesn't change anything.
Now if we let x be anything else, such as sinx then we have [itex](sinx)^n[/itex] and taking the derivative of this is the same as before, but this time the derivative of what's inside (in this case, sinx) is cosx so this makes a difference: [itex]n(sinx)^{n-1}.cosx[/itex]
But you also need to dig deeper and keep taking the derivative of what's inside, if there is something further inside.
e.g. [itex]\left(sin(1/x)\right)^n[/itex]
Again, take the derivative by first applying the power rule, and then taking the derivative of sin(1/x) by using the trigo change, so cos(1/x) multiplies on the outside, but finally you also need to take the derivative of 1/x (this was also done behind the scenes in the 2nd example, we took the derivative of x, but again that's 1) so altogether we get:
[tex]n.\left(sin(1/x)\right)^{n-1}.cos(1/x).\frac{-1}{x^2}[/tex]
And you can of course simplify. Anyway, I know this is terribly set out but I hope you understand it :smile:
