Triple integral problem: cylindrical coordinates
The discussion centers on calculating the volume of Torricelli's Trumpet using triple integrals in cylindrical coordinates. The integral is defined as V = ∫₀¹ ∫₀²π ∫₁¹/r r dx dφ dr, where the volume element in cylindrical coordinates is d³r = dr dφ dx r. Participants clarify the bounds for the integrals, emphasizing that the lowest x-coordinate is 0 and the maximum is always 1/r. The half in front of the triple integral represents the volume of one horn of Gabriel's Horn, which is a specific case of Torricelli's Trumpet.
  • Understanding of triple integrals and volume calculations
  • Familiarity with cylindrical coordinates and their applications
  • Knowledge of the concept of Torricelli's Trumpet and Gabriel's Horn
  • Basic proficiency in calculus, particularly integration techniques
  • Study the derivation of volume using triple integrals in cylindrical coordinates
  • Learn about the properties and applications of Gabriel's Horn
  • Explore the relationship between polar and cylindrical coordinates in integration
  • Practice solving triple integrals with varying bounds and volume elements
Students and educators in calculus, particularly those focusing on integration techniques, as well as mathematicians interested in geometric applications of integrals.
jackscholar
I have a graph 1/x^2=y^2+z^2 where z=rsin(θ) and y=rcos(θ)
where 0≤r≤1 and 0≤θ≤2∏ on the zy-plane
The end result is attached (sorry, I'm not aware of how to use Latex :[ )
I can kind of understand how they determined the first bounds for the integral: the lowest x co-ordinate is 0 and the maximum co-ordinate is always 1/r. I can also kind of understand how they determined the second integral bounds, the maximum possible value for r is 1 and the lowest possible value for r is 0. For the angle the largest possible angle is 2∏ whereas the lowest possible angle is 0. I do not, however, understand why there is a half in front of the triple integral.
hi jackscholar! :smile:
i don't understand what the question is …
is it to find a volume, if so of what?
surely it's from 1 to 1/r ? :confused:
I am trying to determine the volume for Torricelli's Trumpet. I've done it the conventional way but have been want to prove it using the triple integral method. I stumbled across a website which stated a few things and got to the answer but it didn't explain how. I have proved the surface area using a different method to the disk method and would like to prove the volume using a different method but I'm not too good at triple integrals. The website is below, what I was looking at was on page 18 near the bottom and 19 near the top. Could you help m interpret what they are trying to do?
This is the website: http://www.palmbeachstate.edu/honors/documents/jeansergejoseph.pdf
It's easy: it's just the volume of ONE of the horns.
How would I calculate the volume of one of the horns using a triple integral, though?
You use the cylindrical coordinates as given in #1:
\vec{r}=(x,r \cos \varphi,r \sin \varphi).
Then the boundary surface for one half of the horn is given as
x=\frac{1}{\sqrt{y^2+z^2}}=\frac{1}{r}.
Now the volume element in cylinder coordinates is
\mathrm{d}^3 \vec{r}=\mathrm{d} r \mathrm{d} \varphi \mathrm{d} x r.
Now using the definition for Gabriel's horn
http://en.wikipedia.org/wiki/Gabriel's_Horn
It's volume is given by
V=\int_0^1 \mathrm{d} r \int_0^{\varphi} \mathrm{d} \varphi \int_{1}^{1/r} \mathrm{d} x r.
Now you can easily evaluate the integral yourself.
