What is the Region Bounded by a Unit Circle in the yz Plane and x = 0?
The discussion centers on evaluating the integral of \(y^2z^2 dV\) over the region \(W\) bounded by the paraboloid \(x = 1 - y^2 - z^2\) and the plane \(x = 0\). Participants clarify that the region is not merely a circle but the top of a paraboloid, necessitating the correct setup of integration limits. The recommended approach involves converting to cylindrical coordinates, where the integrand becomes \(r^5 \sin^2(\theta) \cos^2(\theta) r dr d\theta dz\), with appropriate limits for \(r\), \(\theta\), and \(z\). The final integral evaluation leads to a result of \(\frac{\pi}{32}\), contrasting with an incorrect calculation of \(\frac{\pi}{4}\).
  • Understanding of triple integrals in multivariable calculus
  • Familiarity with cylindrical coordinates and their application in integration
  • Knowledge of polar coordinates transformations
  • Proficiency in trigonometric identities and integration techniques
  • Learn to set up and evaluate triple integrals in cylindrical coordinates
  • Study the application of polar coordinates in multivariable integrals
  • Review trigonometric identities relevant to integration
  • Practice problems involving the integration of functions over bounded regions
Students and educators in calculus, particularly those focusing on multivariable integration, as well as anyone needing to understand the geometric interpretation of integrals over complex regions.
joemama69
evaluate the integral y2z2dV over W, which is the region bounded by x = 1 - y2 - z2 adn the plane x = 0
since x = 0, that makes y2 + z2 = 1, unit circle in the yz plane right?
so would the answer be the area of the circle times y2z2
uhh? the answer is a number … how can ∫∫∫ y2z2dV have any y or z in it? :confused:
Draw the region. You will see that it is a paraboloid with a maximum at y=z=0 and x=1. The paraboloid is cut off at x=0 so the region looks like the top of paraboloid. Which is not just a circle.
Those integration limits are not correct. For A) if your integration order is dzdydx there will be a z left in your answer. Every other order of integration has a similar problem so it can't be right.
For B) you don't integrate over x,y and z, but over r, theta and x. This means you've to find limits for r, theta and x. The polar coordinates in this case would be x=x, y=r \cos \theta, z=r \sin \theta,y^2+z^2=r^2. Try to find the correct boundaries for both A and B. Realize the region is a paraboloid with an extremum at 1 on the x-axis and cut off by the yz-plane.
I will leave it for you to decide which one is easier.
You might try first swapping x and z so that the integrand is x^2y^2dV and the bounding surfaces are [math]z= 1- x^2- y^2[/math] and z= 0.
In cylindrical coordinates that would be (r^2cos^(\theta)r^2sin^2(\theta) rdrd\theta dz= r^5 sin^2(\theta)cos^2(\theta) and the boundaries [math]z= 10- r^2[/math] and z= 0.
Well I was originally thinking polar was easier but i think I've changed my mind.
BTW I am not using x2y2 and z = 1 - x2 - y2, z = 0
I need help setting up my limits
z.. 0 to 1 - x2 - y2
x... -(1-y2)1/2 to 1-y2)1/2
y... -1 to 1
whats right and what's wrong
So you are integrating over the region bounded by z= 1- x^2- y^2 and z= 0?
I would recommend converting to cylindrical coordinates: x= r cos(\theta) and y= r sin(\theta) so that z= 1- r^2. Don't forget that the "differential of volume" in cylindrical coordinates is dV= r dr d\theta.
If you are required to do this in rectangular coordinates (or just want to), then, yes, your limits of integration are correct. Projecting the parboloid onto the z= 0 plane, you get the circle x^2+ y^2= 1. y going from -1 to 1 will cover that and, for any given y, x will go from -\sqrt{1- y^2} to \sqrt{1-x^2}. Finally, for any given x and y, z going from 0 to 1- x^2- y^2 will cover the solid.
Ok, i tried it in cylindrical but i got my limts wrong
z is from 0 to 1-r2
r is from 0 to \sqrt{1-z}
theta is from 0 to pi
You switched z and x around right? You can't have a z in your limits, it will mean you end up with a variable. The radii of the circular slices vary from the base r=1 to the top r=0. Also to integrate over the full circular slice you need to adjust your \theta limits.
im integrating over dz,dr,dQ Q = theta
dz = 0 to 1-r2
dr = 0 to 1
dQ = 0 to 2pi
\int\int\intr4cos2Q sin2Q r dz dr dQ
Yes that should give you the same answer as the Cartesian method.
ok i got stuck integrating
in integrated z and pluged in the limits and now I am integrating r
\int(r5 - r7)cos2Q sin2Q dr = 1/24 ...
1/24 \int cos2Q sin2Q dQ =
1/24 \int ( - /sin2Q) sin2Q dQ =
1/24 \int sin2Q - sin4Q dQ =
Now I am stuck... my calculator gave me pi/4, but how do i do it by hand
sin^2(Q)- sin^4(Q)= sin^2Q(1- sin^2(Q))= sin^2(Q)cos^2(Q)
Use trig identities sin^2(Q)= (1/2)(1- cos(Q)), cos^2(Q)= (1/2)(1+ cos(Q)). You may need to use those twice.
i haven't those identities in a while
1/24 \intcos2Q sin2Q dQ =
1/24 \int(1/2 + 1/2 cosQ)(1/2 - 1/2 cosQ) dQ =
1/96 \int(1 + cos2Q) dQ =
1/96 \int(1 + 1/2 + 1/2 cosQ) dQ =
1/96 \int(3/2 + 1/2 cosQ) dQ =
1/96 (3Q/2 + 1/2 sinQ)] from 0 to 2pi = pi/32
my calc said it was pi/4 do u see any problems
I would personally start out with \cos^2 \theta \sin^2 \theta=(\cos \theta \sin \theta)^2=\frac{1}{4}\sin^2 (2\theta). This way you can skip a few steps.
You used Halls identities which are incorrect the correct ones are \cos^2x=\frac{1}{2}(1+\cos 2x),\sin^2x=\frac{1}{2}(1-\cos 2x). Note the double angle.
ok when i integrated with the last identity i got pi/96 did u get this too
I got pi/96.
