MHB Why Do Extra Terms Emerge in the Triple Vector Product with Del?
The discussion focuses on the emergence of additional terms when applying the triple vector product with the del operator, specifically in the expression $\nabla \times (A \times B)$. Participants clarify that the bac-cab rule does not apply due to the nature of the del operator as both a vector and a differential operator. The correct formulation results in the equation $\nabla \times (A \times B) = (B \cdot \nabla) A + A (\nabla \cdot B) - B (\nabla \cdot A) - (A \cdot \nabla) B$. This highlights the necessity of understanding the product rule and the component formalism in vector calculus.
  • Vector calculus fundamentals
  • Understanding of the del operator and its properties
  • Familiarity with the bac-cab rule in vector calculus
  • Knowledge of the product rule for differentiation
  • Study the properties of the del operator in vector calculus
  • Learn about the application of the product rule in vector fields
  • Explore the implications of the triple product in vector calculus
  • Investigate the differences between the curl and divergence operations
Students and professionals in physics, engineering, and mathematics who are dealing with vector calculus, particularly those focusing on electromagnetism and fluid dynamics.
ognik
I know the bac-cab rule, but add $\nabla$ and it's not so clear ..
applying it to $\nabla \times \left( A \times B \right) = A\left(\nabla \cdot B\right) - B\left(\nabla \cdot A\right) ...$, not quite
Please walk me through why the other 2 terms emerge ?
bac-cab won't work with the gradient operator. I don't know if you have covered this before but I don't know of an easier way:
Write it in the component formalism:
[math]\nabla \times \left ( A \times B \right )[/math]
This implies
[math]\epsilon _{ijk} ~ \epsilon _{kmn} ~ \partial _{j} ~ (A_m ~ B_n)[/math]
Take the derivative:
[math]= \epsilon _{ijk} ~ \epsilon _{kmn} \left [ ( \partial _{j} ~ A_m) B_n + A_m ( \partial _{j} ~ B_n ) \right ] [/math]
Note the following alteration in the first [math]\epsilon[/math] factor: [math]\epsilon _{kij} = \epsilon _{ijk}[/math] ([math]\epsilon[/math] is antisymmetric in a switch of coordinates and we are making two here.)
[math]= \left ( \epsilon _{kij} ~ \epsilon _{kmn} \right ) \left [ ( \partial _{j} ~ A_m) B_n + A_m ( \partial _{j} ~ B_n ) \right ] [/math]
[math]= \left ( \delta _{im} ~ \delta _{jn} - \delta _{in} ~ \delta _{jm} \right ) \left [ ( \partial _{j} ~ A_m) B_n + A_m ( \partial _{j} ~ B_n ) \right ] [/math]
[math]= \left [ ( \partial _{j} ~ A_i ) B_j + A_i ( \partial _{j} ~ B_j ) \right ] - \left [ ( \partial _{j} ~ A_j ) B_i + A_j ( \partial _{j} ~ B_i ) \right ] [/math]
Moving the vectors around in each term where needed:
[math]= B_j ~ \partial _{j} ~ A_i + A_i ~ \partial _{j} ~ B_j - B_i ~ \partial _{j} ~ A_j - A_j ~ \partial _{j} ~ B_i [/math]
Which implies:
[math]\nabla \times \left ( A \times B \right ) = ( B \cdot \nabla ) A + A (\nabla \cdot B) - B( \nabla \cdot A) - (A \cdot \nabla ) B[/math]
-Dan
Interesting & ta, but why can't we apply bac-cab - del is a vector?
It's a vector, but it's also a differential operator. That means it has to have something to operate on. That is the source of the extra two terms in [math]\nabla \times (A \times B)[/math] vs. [math]A \times (B \times C)[/math].
-Dan
This implies
-Dan
Indulge me please, I think I am undoing some 'wrong knowledge' here.
If I do this using the determinant ('cos it is easier for me to see), then expanding over the top row I would get: $ \partial_x\left( A_yB_z -A_zB_y \right) - \partial_y\left( A_xB_z -A_zB_x \right) + \partial_z\left( A_xB_y -A_yB_x \right) $
Using the product rule: $ = A_y\partial_xB_z + \partial_x A_yB_z - A_z\partial_xB_y + \partial_xA_zB_y - ... $
Obviously you aren't then applying the operators to what follows them (if you did they'd all = 0) - why not please?
You've got the wrong product. Here you are using the "box product" formula:
[math]\nabla \cdot (A \times B ) = \left | \begin{matrix} \partial _x & \partial _y & \partial _z \\ A_x & A_y & A_z \\ B_x & B_y & B_z \end{matrix} \right | [/math]
[math]= \partial _x \left ( A_y ~ B_z - A_z ~ B_y \right ) - \partial_y \left ( A_x~ B_z - A_z ~ B_x \right) + \partial_z \left( A_x ~ B_y -A_y ~ B_x \right )[/math]
This is not the same as [math]\nabla \times ( A \times B )[/math].
-Dan
17K
  • · Replies 20 ·
