Trouble finding the amplitude in a SHM problem
8 replies · 2K views · last reply
frozen-pizza
a horizontal spring-mass is composed of a spring with constant 10.0 N/m and an 80.0 gram mass on the end of the spring. the surface supporting the mass is friction less. when the system is first observed, the spring is extended 1.30 cm and the velocity of the mass is 54.1 cm/s in the negative x direction
a. find angular frequency, linear frequency, and the period.
b. apply the given info and your results from part a to find the values for Xsub m, and Φsub m.
w=sqrt(k/m), f= w/2pi, and t=1/f
x=Acos(w+Φ)
i found w=11.2 f=1.78 and t=.56
for part b i seem to be totally stuck, i would really appreciate a push towards the right direction.
i looking at conservation of energy to find the amplitude but i don't know what energy is so i get stuck with two unknowns.
Hi frozen-pizza and welcome to PF.
You don't need energy. Just evaluate x(t) and dx/dt at t = 0 and set them equal to the given values.
for amplitude i used Vmax=Aw so A=.541/11.2 and i seem to get the right answer, is this right or just a coincidence?
That's the velocity when the spring is at position 1.30 cm. The speed is maximum when the spring is unstretched at the equilibrium position.
yea that makes sense, it just happened to work out then.
ok so if i set x(t)=0 is x(t)=Acos(0+Φ)? if so do i have to set it equal to 1.30 cm?
Yes. Then evaluate the derivative at t = 0 and set it equal to -54.1 cm/s. Solve the system of two equations and two unknowns.
