Trouble with the concept of tension....
The discussion revolves around the concept of tension in a rope during a tug-of-war scenario, exploring the implications of mass and acceleration on tension distribution. Participants are examining the conditions under which tension remains constant or varies along the length of the rope, referencing Newton's laws of motion.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the nature of tension in a rope when forces are applied at both ends, particularly in cases involving a massive rope versus a massless rope. They discuss the implications of unbalanced forces and the conditions for static versus dynamic scenarios.
The conversation is active, with participants providing insights into the behavior of tension under different conditions. Some participants are seeking clarification on the relationship between the forces exerted by individuals and the resulting tension in the rope, while others are emphasizing the importance of considering the mass of the rope and the system's acceleration.
There is an ongoing exploration of the assumptions regarding the mass of the rope and the forces involved in the tug-of-war scenario. Participants are also addressing the implications of Newton's laws in both static and dynamic contexts, highlighting the complexities of analyzing tension in real-world applications.
  • #61
OKAY THANKS A LOT EVERYONE FOR BEING WITH ME AND HELPING ME OUT...i REALLY APPRECIATE YOU GUYS FOR YOUR LOVE FOR PHYSICS AND THE WAY YOU GUYS ANSWERED MY NEVER ENDING QUESTIONS WITH SUCH PATIENCE...THANKS FOR YOUR TIME AND NOW I CAN FINALLY SAY THAT U HAVE REDUCED MY TENSION REGARDING TENSION.! Hope to see you guys again with some other box of doubts.
REGARDS,
Achintya(From INDIA)
  • #62
REGARDS,
Finally, to go back to a question I asked many post ago about a tug-of-war in space. In that scenario, each astronaut accelerates according to how much he/she pulls the rope and independent of how much the other pulls the rope.
  • #63
YES! got that.. but on Earth surface we don't accelerate with our own force because we get a equal and opposite reaction from the ground...right?
  • #64
We do not accelerate due to the force of the rope on our hands because there is an equal and opposite force from the ground, yes.
But that force from the ground is not a "reaction" force.
Conventionally we reserve the term "reaction force" to refer to the third law partner of a given force. The force of the ground on your feet is not the third law partner to the force of the rope on your hands. The third law partner of the force of the rope on your hands is the force of your hands on the rope.
The third law assures us that momentum is conserved for the system as a whole. Any momentum lost by A due to the force on it from B is equal and opposite to the momentum gained by B due to the force on it from A.
  • #65
Adesh said:
Take a rope which is not attached to any thing, if you pull it then it will certainly going to move and the stretch in the rope will be due to molecular attraction/repulsion.
No. It will stretch because it has mass if it is accelerating. (N2)
  • #66
Now that the answer has been sorted out, I should point out that having 20 N at one end of a string and 30 N at the other is not as unphysical as it may look. Imagine an Atwood machine with 20 N and 30 N at each end. The 20 N weight is tied to the floor with a second string that is under tension. Clearly the tension in the Atwood string is 30 N and the tension in the floor string is 10 N; the system is in equilibrium and the acceleration of each mass is ##a=0.## At ##t=0## the floor string is burnt with a blowtorch. What is the acceleration at ##t=0?## If we agree that some finite time is required for the acceleration to jump from zero to the steady-state common value, ##a=\dfrac{m_2-m_1}{m_2+m_1}g##, then it is reasonable to conclude that the tension is 20 N at one end and 30 N at the other at ##t=0.##
  • #67
Achintya said:
so you mean once the system accelerates there will be no tension in the rope?
Imagine the rope modeled as a series of small masses connected by hook's law springs. A change in the force exerted at one end of the rope is not instantly transmitted to small mass at the other end. If unequal forces act on opposite ends of the rope at time t = 0, the motion of the masses can be quite complicated. the tensions in the springs can be different and change as a function of time.
So if you want to talk about "the" tension in such a model, you have to imagine the system getting into a steady state where all the tensions in each spring are constant. However, if we are using idealized springs that don't dissipate energy, this will never happen. The system can oscillate forever as it (as a whole) accelerates.
  • #68
restating the question. A is pulling a massless rope with 10N, B is pulling in opposite direction of A with 20N. What is tension on string? It is 15N.
10N<---A--->------<---B--->20N
Let us assume mass of A and B = 1kg. Let us denote tension on rope = Ft. Let us denote acceleration of A&B=a
freebody diagram of A:
10N<---A--->Ft
Ft-10N=1*a
freebody diagram of B:
Ft<---B--->20N
Ft-20N=-1*a
-1*a because Ft and a are in opposite directions for B
Equation1: Ft-10N=a
Equation2: Ft-20N=-a
Equation1-Equation2: 10N=2a
a=5N
Ft=15N
  • Skeptical
  • #69
You should open a new thread. Your answer makes little sense to me.
  • #70
You realize that thread is 2 years old. That said, your free body diagram is incorrect. If the rope is the only entity that exerts a force on A and B, the direction of the force on A is from A to B and the direction of the force on B is from B to A. These two are equal and opposite according to Newton's third law.
  • #71
kkps said:
Ft-10N=1*a
No. That equation says -10N is the force A is exerting on the ground. Your equations lead to A exerting a force -15N on the rope and B exerting a force +15N on it.
  • #72
10N<-A---ROPE---B->20N
is not different from
<-A(say 1Kg)hanging on a rope on left of pulley---ROPE---B(say 2Kg)hanging on a rope on right of pulley
this is same as Atwood machine problem
of course, we can add force on ground etc. to problem and complicate, but it is not needed to solve the problem IMO
I think it can be solved by my simple free body diagram which are drawn similar to Atwood machine solution
and, of course, i am assuming massless rope to simplify
yes, but i think someone will still search for this, and i think the question was not answered well
  • #73
please see my answer to kuruman. A is pulling on rope with 10N to left, B is pulling on rope with 20N to right. we do not have to add Ground in picture, A is somehow generating 10N, B 20N. Then we can translate the question to an Atwood machine problem
I have still not answered the "rope with mass" part of the original question. I am working on it :cool:
  • Sad
  • #74
My answer is treating the problem like an Atwood machine problem. I think I forgot to mention that I am treating the string as massless. I am working on a simple explanation for the "string with mass" case. I think this thread is a good interaction, though there is lot of unnecessary confusion in the discussion. But the original question is a doubt anyone could have
  • #75
Which you've just added to! Your solution is conceptually wrong, as it violates Newton's third law, which I think has already been pointed out.
  • #76
can you explain why this question cannot be simplified to an Atwood machine question as I pointed out in reply to kuruman? After that, can you explain why my solution is conceptually wrong and how it violates Netwon's third law?
FBD of A
10N<-A->15N A is moving to right with a=5, if m of A=1kg
FBD of B
15N<-B->20N B is moving to right with a=5, if m of B=1kg
FBD of rope
15N<-Rope(massless)->15N
what force is not balanced violating third law?
  • #77
B cannot be pulling on the string with ##20N## and the string pulling back with ##15N##. That violates Newton's third law.
  • #78
That is the proposition in post #1. It appears to be a situation invented by the student, not a problem he or she was given.
If the rope has zero mass then it is not physically possible, and if you start with an impossible combination of facts you can deduce anything.
  • #79
In post #68 you described your equations as based on free body considerations for A and B. Necessarily that means your are considering all horizontal forces on those bodies, namely, the force from the ground and the force from the rope.
If your FBD has the force of tension and the force of a person pulling, what is the body those two forces are acting on?
You seem not to understand the concept of an FBD.
  • #80
to make it simple, translate the question to this:
A(1Kg)hanging on a rope on left of pulley---massless ROPE---B(2Kg)hanging on a rope on right of pulley
in the above (pulley) case, the entire system (A-rope-B) will fall to right
This is an Atwood machine problem
The original question is exactly same as I see it
solution to above Atwood problem is: a=5, Ft=15
it is very much possible. that is what causes motion!
  • Skeptical
  • #81
you are trying to prove that the question makes no sense, but the question makes a lot of sense to the original poster. I am trying to understand what the original poster meant, and answer the intent of the original poster.
Most textbooks have similar questions where, say, A pulls something to left. All that the student has to consider to answer the question is that there is a force to left. There is no need to consider where the force is coming from, the type of shoes he is wearing, the surface he is standing on (ice vs slush), etc.
Imagine you are in a classroom and the teacher has asked this question, and imagine the teacher walked away. You would answer the question making some assumptions yourself, rather than heckling the teacher with more questions. I am taking this approach
Also, zero mass of rope is used in all basic textbooks in all such problems. if you add mass, your answer is not going to be much different . I will post that answer soon
  • Skeptical
  • #82
please see post #80
IMO, post #1 is asking the same question as shown in the diagram of post #80
(as I mentioned in post #81, some simplification of original question can be applied to give a meaningful answer without further questioning - force from ground etc. are irrelevant to the original problem)
  • #83
If the original poster intends a massless rope then the question posits an impossible scenario according to Newton's second law. ##\sum F = ma##. ##m = 0## so ##\sum F = 0##.
If the original poster intends a rope with mass then the scenario is possible.
Both possibilities have been contemplated in already. For instance, see post #6 which contemplates a massless rope and #8 which looks at both scenarios -- a rope with or without mass.
The possibility of A pulling on the rope with 20N and the rope pulling on A with 15N is a direct violation of Newton's third law and is nonsense.
  • #84
Please don't!
  • #85
Let's examine and interpret the equations in your drawing. You have
Equation 1: Ft - 10 = 1*a
Here Ft is the tension, 10 (N) is the weight of the mass on the left and 1*a is mass*acceleration
Equation 2: Ft - 20 = 1*(-a)
Here Ft is the tension, 20 (N) is the weight of the mass on the right and 1*(-a) ##\dots~## is what ? If the mass is 2 kg, the term should be 2*(-a) to be correct. Then one has
Ft - 10 (N) = a
Ft - 20 (N) = -2a
If the first equation is doubled and added it to the second, one gets
3 Ft - 40 (N) = 0 ⇒ Ft = 40/3 (N) = 13.3 (N) and that is the correct tension in the string connecting the masses. More generally, $$F_T=\frac{2m_1m_2}{m_1+m_2}g.
  • #86
kkps said:
B cannot be pulling on the string with 20N
Indeed, it is not. Gravity pulls on B with 20N, but if B is accelerating at 5m/s2, B only pulls on the string with 15N, same as the tension.
What if we let A's mass dwindle to zero? B will be in free fall, so no tension, but according to your reasoning it is still pulling on the string with 20N.
  • #87
PeroK said:
Please don't!
Well, it would be interesting to see that, and take the limit as the rope's mass tends to zero.
  • #88
haruspex said:
Indeed, it is not. Gravity pulls on B with 20N, but B is accelerating at 5m/s2, so B only pulls on the string with 15N, same as the tension.
For ##m_1 = 1## kg and ##m_2 = 2## kg, the acceleration is $$a=\frac{m_2-m_1}{m_2+m_1}g=\frac{1}{3}g$$and the tension is 13##\frac{1}{3}## N as indicated in post #85.
  • #89
Thanks. I made the mistake of assuming @kkps's numbers were correct, just the interpretation that was wrong. I've edited it to avoid making that assumption.
  • #90
To @kkps :
Here is a multiple choice question to help you sort this out.
Two teams are engaged in a tug o' war as shown in the figure below. The team on the left is pulling on the rope with a force of 100 N and the team on the right with a force of 200 N. A force gauge is attached to the rope as shown. What does the gauge read?
(A) 100 N
(B) 150 N
(C) 200 N
(D) The people on the left read 100 N and the people on the right read 200 N.
(E) This question makes no physical sense.
Hint: How would your answer change if the right side of the gauge were attached to an immovable wall instead of being pulled by the team on the right? What about swapping the left team with the immovable wall?
  • · Replies 18 ·
