Troubleshooting Lie Brocket Connection Issues
The discussion revolves around the properties of Lie brackets and connections in differential geometry, specifically addressing how to demonstrate that a Lie bracket does not satisfy the properties of a connection. Participants also explore proving that a specific curve is a geodesic, discussing various approaches and challenges encountered in the process.
  • Homework-related
  • One participant seeks to demonstrate that the Lie bracket is not a connection, prompting others to suggest identifying properties that distinguish them.
  • Another participant suggests checking properties of connections one by one to find discrepancies with the Lie bracket.
  • A participant expresses frustration after reviewing properties without finding differences, indicating a desire to move on to another question.
  • Participants discuss proving that a curve V(t) is a geodesic, with one proposing that V(t) is geodesic if V'' = 0, while another mentions calculating ||V'||^2 = constant as an alternative approach.
  • There is mention of evaluating expressions involving vector fields and smooth functions, with a request for assistance in understanding the calculations.
  • One participant provides a specific form of a geodesic and describes difficulties in calculating the second derivative, indicating that the first derivative still contains a variable.
  • Clarifications about notation in LaTeX are provided, with a reminder about proper syntax for mathematical expressions.
Participants do not reach a consensus on the properties that differentiate Lie brackets from connections, and multiple approaches to proving geodesics are discussed without resolution. The discussion remains unresolved regarding the specific properties and methods to demonstrate the claims.
Limitations include potential misunderstandings of definitions and notation, as well as unresolved mathematical steps in proving the geodesic condition.
wii
hi there,
how can i show that the lie brocket is not connection?
Many thanks =)))
Can you think of a property that a connection has, that the Lie bracket for vector fields doesn't? The definition of "connection" doesn't list that many properties, so you can check them one at a time. For example, a connection is ℝ-linear in both variables, and so is the Lie bracket for vector fields. That doesn't help, so you need to keep checking until you find a property that this Lie bracket doesn't have.
Thanx Fredrik
could you please help me to find the property that is not satisfied?
Yes, but I don't want to do your work for you. If you post the properties that you know a connection must have, and your attempts to determine if a Lie bracket has those properties too, I will tell you if you're doing something wrong. If you get stuck, show me where, and I'll try to help you get past that point.
Hello !
Actually I check all the properties of the connection and I can not find out any different and I give up =|
any way, let's ignore it :\
I have another question =)
If we want to prove that V(t) is a geodesic of 6(u,v) OK?
So, I try to prove that by the fact " V(t) is geodesic iff V'' =0 " and also I try to do that by calculate ||V'||^2 = constant.
but both of them did not work =(
is there any different way to prove that V(t) is geodesic ?? please your advice
Thanx =)
Can you evaluate the following expressions, where X and Y are arbitrary vector fields, and f is an arbitrary smooth function?
[tex]\nabla_{X}(fY)(p)[/tex]
[tex][X,fY]_p[/tex]
Click the quote button, and you'll see how I did the LaTeX. If you try it, you need to keep in mind that there's a bug that makes the wrong images appear. The only workaround is to refresh and resend after each preview.
The policy around here is that people who ask for help with textbook-style problems have to show a complete statement of the problem, the definitions they're using, and their work so far, so that we can give hints that will help them move past the point where they are stuck.
I don't understand what you're asking. what is V(t)? What do you mean by 6(u,v)? What manifold are you talking about, and what metric/connection are you using?
If [tex]f(x)[/tex] is a positive function and
[tex]/sigma(u,v)[/tex] [tex]/eq(f(u)cos(v),f(u)sin (v),u)[/tex] then
[tex]/gamma(t)[/tex] = [tex]/sigma(u(t),c)[/tex]
is a geodesic where c is constant between 0 and [tex]/pi[/tex]
that was the question and I tried to calculate the second derivative of /sigma but that did not work and we still have u in the first derivative which means it is not constant :confused:
and thank you Fredrik =)
f is a real function
[tex]\sigma(u,v)[/tex] [tex]\eq(f(u)\cos(v),f(u)\sin (v),u)[/tex] then
[tex]\gamma(t)[/tex] = [tex]\sigma(u(t),c)[/tex]
is a geodesic where c is constant between 0 and [tex]\pi[/tex]
In LaTeX, you need to use \ instead of /. For example, \sigma instead of /sigma. I also recommend \cos instead of cos.
I don't have time to look at your problem today. Maybe someone else does.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 30 ·
  • · Replies 0 ·
