Troubleshooting Matrix File Uploads: Why Am I Getting Zeros?
  • Context:
  • Thread starter Thread starter BRN
    File Matrix
The forum discussion addresses an issue with a C++ template function for reading a matrix from a file, where the output contains unexpected zeros. The user initially provided input data without delimiters, leading to incorrect parsing. The solution involved adding spaces between matrix elements in the input file, which resolved the issue. The discussion highlights the importance of using delimiters for multi-digit numbers and ensuring the input format matches the expected matrix structure.
  • C++ programming knowledge, specifically with templates and streams
  • Understanding of std::stringstream and its operator behavior
  • Familiarity with file I/O operations in C++
  • Basic knowledge of matrix data structures
  • Explore C++ std::stringstream for advanced input parsing techniques
  • Learn about matrix initialization and memory management in C++
  • Research best practices for file formatting and data delimiters
  • Investigate error handling in C++ file I/O operations
C++ developers, software engineers working with file I/O, and anyone involved in matrix data manipulation and parsing in programming.
BRN
Hello everybody,
I created this tamplet to upload a file matrix:
[CODE lang="cpp" title="Load Matrix"]
#include <sstream>
#include "fstream"
#include <vector>
#include <iostream>
#include <string>
template<class T >std::istream& readMatrix(std::vector<std::vector<T>>& outputMatrix, std::istream& inStream)
if (inStream) {
std::string line;
while (std::getline(inStream, line)) {
outputMatrix.emplace_back();
// Break down the row into column values
std::stringstream split(line);
int value;
while (split >> value)
outputMatrix.back().push_back(value);
return inStream;
[/CODE]
Unfortunately it does not provide me with the correct output. I get this:[CODE lang="cpp" title="Output"]
input:
1234
5678
9123
4567
output:
1234 0 0 0
5678 0 0 0
9123 0 0 0
4567 0 0 0
[/CODE]
I can't understand why I get those zeros. Any idea?
Technology news on Phys.org
Did you mean to write split > value or split >> value?
I don't understand where the split values are assigned.
It seems you've called a split(line) function which I assume returns an array of values.
Your matrix file format is ambiguous unless you can absolutely guarantee that every entry will only ever be a single digit number. If one line is 12345 should that be 12,3,4,5 or 1,23,4,5 or 1,2,34,t or 1,2,3,45? You should put in delimiters such as spaces or commas.
I think what's happening is that you have told your stream to read values from each line in your input until it runs out of input. It reads the first value 1234, which is a valid four digit number, and finds nothing else on the line so goes on to the next line. You need to look at how std::stringstream's operator>> works with delimiters if you want to potentially use more than one digit, or consider using get() instead if you genuinely only want single digit numbers and no delimiters.
The code looks fine to me. And when I run it, it works as expected: I created a file data.dat with the entries
1234
5678
9012
3456
and ran it with your code, extended by a main
Code:
int main() {
    using namespace std;
    ifstream file("data.dat");
    vector<vector<int>> matrix;
    readMatrix(matrix, file);
    for(const auto& row: matrix) {
        for (const auto& entry: row) {
            cout<<entry<<" ";
        cout<<endl;
When I run the program, I get exactly the expected 1x4 matrix that is in data.dat - no zeroes added. I suspect the problem is in your input stream, not in the code you use to parse it.
The splitting looks fine to me too. And a similar example runs as it should.
On 2nd though, here is another suspicion what goes wrong: Check the code where you output your matrix: Maybe your code assumes a 4x4 matrix and fills the missing entries with 0 or access to uninitialized memory locations like matrix[0][1]?
Exactly, this was the problem. I inserted a space between each matrix element in the file and is now loaded correctly.
Yes, this happened. My code interpreted my file as a single column of 4 values and consequently added three other columns of zeros.
Thank you all for your answers!
  • · Replies 75 ·
  • · Replies 16 ·
9K
