True/False differentiation problem
  • Context:
  • Thread starter Thread starter Saitama
    Differentiation
8 replies · 3K views
Saitama
Problem:
Let $g(x)$ be twice differentiable function satisfying $g(0)=0$, $g(1)=1$. Then, which of the following is/are correct?
A) there exist distinct $C_1,C_2\in (0,1)$ such that $g'(C_1)+g'(C_2)=2$.
B) there will be atleast one $C$ such that $g'(C)=1$ for $C\in (0,1)$
C) there will be atleast one $C\in (0,1)$ such that $g(C)=C$ for $C\in (0,1)$
D) if $g(\alpha)=\alpha$ for $\alpha \in (0,1)$ then there will exist atleast one $C\in (0,1)$ such that $g''(C)=0$.
Attempt:
The given answer is A, B and D. I have shown that B and D are true and C is false but I am not sure how to begin with proving A. I really don't know where to start.
Any help is appreciated. Thanks!
Pranav said:
Problem:
Attempt:
Hi Pranav,
Let me give some ideas for proving (A). Basically we have to apply the Mean Value Theorem twice. There exist $C_1\in(0,\,1)$ such that,
\[f'(C_1)=\frac{f(1)-f(0)}{1-0}=1\]
Now again apply the mean value theorem considering the points $C_1$ and $0$. Then you'll get a point $C_2\in (0,\, C_1)$ such that, $f'(C_2)=1$. Hope you can continue. :)
Hi Sudharka! :)
I am not sure but intuitively, I think this isn't necessarily true. For example, consider the graph shown in attachment. There is no $C_2$ in $(0,C_1)$ where $g'(C_2)=1$. What's wrong with my thinking? :confused:
Pranav said:
Hi Sudharka! :)I am not sure but intuitively, I think this isn't necessarily true. For example, consider the graph shown in attachment. There is no $C_2$ in $(0,C_1)$ where $g'(C_2)=1$. What's wrong with my thinking? :confused:
Oh sorry. As you see there's a mistake in my previous post. Using the mean value theorem (for the first derivative) on the points $(0,\, C_1)$, we can only get $f''(C_1)=\frac{f'(C_1)-f'(0)}{C_1}$ which doesn't mean a thing. I confused it somehow and thought $f'(C_1)=1$.
I am still not sure where to start. Why are you dealing with the second derivative? Can you please explain a little more?
What happens if you apply the MVT to $[0,1/2]$ and $[1/2,1]$?
Define $f(x) = g(x) - g(1-x)$.
On the one hand, this establishes a stronger fact because not only $g'(C_1)+g'(C_2)=2$, but also $C_1+C_2=1$. On the other hand, it may happen that $C_1=C_2=1/2$, while the problem requires distinct points.
The solutions above require only that $g$ satisfies the MVT on $[0,1]$, i.e., that $f$ is continuous on $[0,1]$ and $g$ is differentiable on $(0,1)$. It is not required that $g$ is twice differentiable. However, a quick-and-dirty way to see that A) is true (say, on a test) is as follows. We know that $g'(c)=1$ for some $c\in(0,1)$ by applying the MVT to $g$. If $g'$ continuous on $[0,1]$ (which happens when $g$ is twice differentiable on $[0,1]$), then it is possible to disturb $g'(c)$ a little so that it becomes $1+\delta$ and $1-\delta$ in two different points. More precisely, $g'(x)$ attains its maximum $M$ and minimum $m$ and we have $m\le1\le M$. Then either $m=M=1$ or $m<1<M$. (If, say, $m=1<M$, then $g$ grows at least as fast as $y=x$, but on some interval, due to continuity of $g'$, it grows strictly faster that $y=x$, so $g(1)>1$.) If $m=M=1$, then $C_1,C_2$ can be any points in $[0,1]$. Otherwise, it is possible to select a $0<\delta<\min(1-m,M-1)$, so $1-\delta$ and $1+\delta$ are in $[m,M]$. By the IVT applied to $g'$ there exist $C_1,C_2$ where $g'(C_1)=1-\delta$ and $g'(C_2)=1+\delta$.
Thanks Evgeny.Makarov and ThePerfectHacker! :)
