Finding Force in Element D-C of a Truss
The discussion focuses on calculating the force within element D-C of a truss, with the user having successfully solved for other forces but struggling with this specific one. Relevant equations for equilibrium, including the sum of forces in both x and y directions, as well as the sum of moments, are provided. The user is encouraged to apply the same analytical methods used for joints A and E to either joint C or D to determine the force in member CD. The thread includes links to visual aids showing the truss and the user's calculations. Ultimately, applying consistent methods across different joints is key to solving for the unknown force.
toolpusher123
I've solved all but one force. I can't seen to get the force within element D-C. All relevant variables are shown on the pics attached i.e loads, supports, dimensions etc...
Sum of forces in x=0, sum of forces in y=0, sum of moments=0
on
Here are links to;
  1. Pic of truss: https://app.box.com/s/20kw3vfcrywrcimshta6
  2. Working for node A: https://app.box.com/s/7d70e0ikgmym08u4bqqj
  3. Working for node E: https://app.box.com/s/kbiyjv9v1u58sxg0g9lz
Why don't you try applying the same methods that you used to find the forces at joints A and E to either joint C or joint D, this should give the force in the member CD
