Trying to conceptualize angular momentum.
Understanding angular momentum can be challenging, especially when comparing it to linear momentum. The angular momentum vector is perpendicular to the axis of rotation, with its direction indicating whether the spin is clockwise or counterclockwise. The use of the cross product in calculating angular momentum provides a consistent mathematical representation that aligns with physical properties, despite seeming arbitrary. The right-hand rule is a convention that helps visualize the direction of angular momentum, though it could theoretically be represented differently. Overall, the discussion emphasizes the importance of conventions in physics for clarity and consistency in understanding rotational dynamics.
undereducated
I'm currently taking a college level physics course, and I'm struggling with the idea of angular momentum, whereas linear was fairly intuitive I guess something seems amiss when trying to understand rotational applications. Let's take the idea of a spinning wheel. The direction of angular momentum is a cross product giving it a direction perpendicular to the wheel this seem odd as no component of the wheel is moving in this direction. I've seen applications like gyroscopes but I guess I don't really understand, If anyone has anything to help explain angular momentum it would be appreciated. This is a first post, I've really been quite taken with physics since enrolling in this class, and this forum appears to be a gold mine of resources. Thank you in advance.
Yeah, the direction of the the angular momentum vector can seem rather perplexing at first. I'll gloss over the technical explanation and try to give you an intuitive one.
As you know, when an object is spinning around an axis, it can spin either clockwise or counterclockwise. Assuming an object is located at the origin, the angular momentum vector will happen to be along the axis it is spinning around. Furthermore, whether the vector is pointing up or down (relative to the position and linear momentum vectors) tells you whether it is spinning clockwise or counterclockwise. The magnitude of the vector tells you how much angular momentum it has.
One reason that we do this instead of pointing the vector in the direction the object is spinning is that if you have a vector pointing in the direction it is spinning, how do you know where to "attach" the vector to the object to determine the direction it is spinning? You might say that we can just attach it to the r we used. But then, the direction of the vector would only make sense for one given r, when the actual formulation makes sense for all given r.
If you need anything elaborated on, just say so.
Appreciate the answer monocles, but to tell you the truth I'm still fuzzy. I'm with you on why it is practical to attach the vector to the axis of rotation. It seems that there is more to the direction of that vector though, than just bookkeeping. I guess I'm wondering how the direction of spin imparts a physical property to the object that affects it in a direction other than the way its spinning . Maybe my question is mathematical, why cross product? Because that's what's giving it the perpendicular direction, no? Anybody got a good derivation for dummies on this. I think a lot of people in my class just want to know how to 'work' the problems so we seem to avoid the 'why' a little bit.
Consider the alternative of using a two dimensional "disc" to represent angular components. The size of the disc could represent the magnitude, and the axis of the disc would be the axis of rotation of the object being represented. The problem is how to perform math on planes instead of vectors.
Vector math is easier, so vectors are used to deal with angular momentum, torque, acceleration, ... The vector coincides with the axis of rotation, and the length of the vector represents a magnitude.
Angular position is a bit tricky, since it's just an angle, and you'd need some consistent rule for what a position of zero angle is.
Regarding cross product, it just works out that the cross product of a linear radial vector and a linear tangental vector produces an appropriate vector to represent an angular quantity, such as torque = radius times force.
That's interesting! I think area is also a cross product - do you think that's a way to go from your disc idea to the cross product?
why does the angular momentum go through the z axis?
i.e for like a spinning top,
i don't get why, i would've thought it was along the x-axis due to some kind of PI product?
L=IW
It's actually located in the X-Y plane but as I mentioned above, how do you do math with "planes" or "discs" as opposed to vectors? It's just a convention to mathematically represent angular momentum as a vector perpendicular to the plane of rotation.
I'll briefly elaborate on "why cross product?" Consider the picture vorcil posted. Another reason that the cross product is convenient is that if the disk is spinning counterclockwise, the L vector will point along the +z axis. If it is spinning clockwise, the L vector will point along the -z axis. This allows you to tell which direction the disk is spinning based on the direction of the L vector.
I think it's just bookkeeping. To me it's very natural that the cross-product represents rotation because of the right hand rule. When you do axb, you use your right hand and curl (rotation!) your fingers to sweep a into b, and where your thumb points gives you the direction. Using your right hand instead of left is just a convention, just like clockwise and anticlockwise are conventions.
I know there are two right hand rules. Some people use the one where three fingers stick out. I'm talking about the one in this picture: http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/magfor.html.
O.K. So maybe the question is why does the right hand rule apply in nature. When you look at something like precession, torque on a angle of rotation, it seems that the direction of the vector is anything but arbitrary (or bookeeping), as the angle of momentum determined by the right hand rule, will seem to chase the direction of the torque.
undereducated said:
Why does the right hand rule apply in nature?
It doesn't, left hand rule would work just as good. In the cases of charged particle centripetal acceleration perpendicular to fields, we chose a sign for the direction of the fields and particles that work with right hand rule. We also chose to mathematically represent current flow in the opposite direction of electron flow, something that could be changed but isn't because we can't teach the old mathematicians and physicists new tricks.
Ahhhh, thanks Jeff. I see what you are saying. My precession example (I saw the old bicycle wheel on a stool bit) is really just a relationship between two angular momentums, and the direction of vectors just keeps track of the spin. Its a matter of convention that allows you to be consistent. Good to know. Thanks everybody.
