Trying to derive the rotational acceleration.
8 replies · 3K views · last reply
PhillipKP
Ok I'm trying to derive [tex]a=v^2/r[/tex]
The Boas book gives me two equations to start off with:
[tex]r^2=\vec{r}*\vec{r}+constant[/tex]
and
[tex]v^2=\vec{v}*\vec{v}+constant[/tex]
Where the hell did those equations come from. I know it gives me the right answer but I don't understand. I can actually do the rest of the derivation easily.
Thanks
As a grad student I am embarressed I don't know this.
I'm no help on those equations, but can you see how to derive the centripetal acceleration just from the nature of the circular motion, and using differentiation?
Are you sure it is [tex]r ^ 2 = \vec{r} . \vec{r} + \mbox{constant}[/tex]?
It doesn't seem true. =.="
We have:
[tex]\vec{r} . \vec{r} = |\vec{r} | \times |\vec{r} | \times \cos ( \vec{r}, \vec{r}) = r ^ 2[/tex].
Well, so it's either the constant is 0, or there is no need to write constant here.
The question says to first expand the rght side of
[tex]\vec{a} = \vec{\omega} \times \left( \vec{\omega} \times \vec{r} \right),[/tex]
and then to assume that [itex]\vec{r}[/itex] is perpendicular to [itex]\vec{\omega}.[/itex]
What do you get when you do the first step?
and
Sorry I had a typo in the first one. Here's the complete passage.
Consider the motion of a particle in a circle at constant speed. We can then write
[tex]r^2=\vec{r}*\vec{r}=constant[/tex]
and
[tex]v^2=\vec{v}*\vec{v}=constant[/tex]
If we differentiate these two equations using (the rules for differentiating a dot product), we get...
The context: Chapter 6.4 Differentiation of Vectors.
Don't you want to use plane polar coordinates?
Anyway, with the way you (i.e. Boas) are doing it, the problem is that you don't really understand why the two equations are chosen? The answer is simply that it is a good place to start, and how you know how to start there comes from a experience and thought. There are many ways to derive centripetal acceleration, and you do not have to start with
[tex]r \cdot r = c_1[/tex]
and
[tex]v \cdot v = c_2[/tex].
Since you are a bit confused, I urge you to derive centripetal acceleration another way. Calc 3 methods can do it very easily, or plane polar.
I can derive it other ways, but I want to understand where this is coming from.
Constant speed ( [tex]\vec v\cdot \vec v = const[/tex] , where [tex]const[/tex] is independent of time ) in a circle [of constant radius ( [tex]\vec r\cdot \vec r = const_2[/tex] , where [tex]const_2[/tex] is independent of time ).
By taking derivatives with respect to t, you obtain [geometrical] relations between the acceleration, [constant speed] velocity, and the radius of the circle.
