Trying to find limit involving continuity concept
To ensure the function f(x) is continuous everywhere, the left-hand limit (x^2 - 9) must equal the right-hand limit (6x - 18) at x = c. Setting these two expressions equal leads to the equation c^2 - 9 = 6c - 18. Solving this results in c^2 - 6c + 9 = 0, which simplifies to (c - 3)^2 = 0. Thus, the value of c that makes the function continuous is c = 3.
Torshi
Find c such that the function f(x) { x^2-9 while x≤ c and 6x-18 x > c } is continuous everywhere.
Given above. Basic algebra.
I made a number line. Showing that x^2-9 is approaching from the left side and 6x-18 is approaching from the right side given the designation of the inequality.
If there were numbers, I could easily do it, but the "c" is throwing me off.
An attempt to a similar problem with numbers would simply be chug and plug and knowing which side it comes from left or right, and if there was a variable "a" in there as well you can substitute.
I have no idea how to start the problem, would it become c^2-9 and 6c-18? and try to solve for c?
##f(x)=\begin{cases} x^2-9 & \mbox{if } x \leq c\\ 6x-18 & \mbox{if } x>c\end{cases}##
For ##f(x)## to be continuous at ##c##, you must satisfy
##\displaystyle\lim_{x\to c^{+}} f(x) = \displaystyle\lim_{x\to c^{-}} f(x)##
That is,
##\displaystyle\lim_{x\to c^{+}} x^2-9 = \displaystyle\lim_{x\to c^{-}} 6x-18##
That's basically what (it seems) you've done already, but this is the reasoning behind the step you've taken.
IMO: It's more important to know why a method works than to know a method without understanding it.
So, here are some questions:
What is necessary in order that f(x) be continuous at x = c ?
What is \displaystyle \lim_{x\to c^-}\,x^2-9\ ?
What is \displaystyle \lim_{x\to c^+}\,6x-18\ ?
That is,
But I don't know how to move on from there.. I end up getting something like x/x = √-3
do you have to set the two limits equal?
If you solve c2-9 =6c-18 for c,
how do you get x/x = √-3 ?
There is no x in c2-9 =6c-18 , and x/x = 1 .
Yes, which should be clear if you answer the question about the function being continuous at x = c .
I put x because the other poster. But, essentially wouldn't it be:
c^2-9 = 6c-18
c^2=6c-9
c^2/c = -3
..idk what to do ... if c was a number in the inequality then i could easily do this problem
alright hold on..
bump
nvm got it.
Since f is continuous everywhere, it is continuous at x = c.
So the left-hand limit must equal the right-hand limit. Thus:
c^2 - 9 = 6c - 18
c^2 - 6c + 9 = 0
(c - 3)^2 = 0
c = 3
thank you!
Yes, that's what I was suggesting.
  • · Replies 22 ·
  • · Replies 40 ·
