Trying to reconcile two definitions of Entropy
The discussion revolves around the definitions and interpretations of entropy, exploring its role in thermodynamics and statistical mechanics. Participants examine different perspectives on entropy as a measure of heat dispersion and disorder, and how these concepts relate to macrostates and microstates. The conversation includes theoretical aspects and implications for models such as the Ising model.
  • One participant describes entropy as a measure of the tendency to disperse heat, referencing Maxwell's relations and questioning how this relates to the behavior of systems at different temperatures.
  • Another participant suggests that the equation mentioned primarily reflects temperature rather than entropy itself, indicating that the overall entropy increases when heat flows from a warmer to a colder body.
  • Entropy is also discussed as a measure of disorder, with examples involving the arrangement of books and the implications of information on the number of states available to a system.
  • Concerns are raised about the use of "order" and "disorder" as analogies for entropy, with a caution that these terms can be difficult to define clearly.
  • A distinction between macrostates and microstates is introduced, with one participant defining microstates as different arrangements that maintain the same macroscopic state.
  • Another participant elaborates on the relationship between macrostates with a greater number of microstates and higher entropy, explaining how systems evolve towards equilibrium states with maximum entropy.
  • References to the Ising model and its connection to entropy, phase transitions, and the behavior of spins at different temperatures are mentioned as part of the exploration of entropy's meaning.
Participants express differing views on the definitions and implications of entropy, particularly regarding its relationship to heat dispersion and disorder. There is no consensus on the best way to reconcile the various interpretations of entropy presented in the discussion.
Participants note the complexity of defining "order" and "disorder" in relation to entropy, highlighting the potential for misunderstandings in these concepts. The discussion also touches on the limitations of analogies used to explain entropy and the need for clarity in definitions.
This discussion may be of interest to students and researchers in physics, particularly those studying thermodynamics, statistical mechanics, and related models such as the Ising model.
badatstuff
My question is regarding a few descriptions of Entropy. I'm actually unsure if my understanding of each version of entropy is correct, so I'm looking for a two birds in one stone answer of fixing my misunderstanding of each and then hopefully linking them together.
1) A measure of the tendency to disperse heat: eg maxwells relations (dS/sU)_[v constant] = 1/T says if you increase the energy of a system while T is low, it has more of an affect on entropy than if you increased the energy by the same amount on a system with high T.
If you place two systems S_1 and S_2 in contact with each other with temperatures T_1 > T_2 then eventually it reaches equilibrium. But the 1/T relation means the entropy of the colder body increases faster than loss of entropy of the warmer body?
2) Entropy is a measure of "disorder" eg a typical examples given in textbooks - someone unbiased of the final outcome stacking of books on a book shelf in completely random orientations, the odds of them being all in alphabetically in order is low due to the number of states. Entropy is a measure of the number of states. You can reduce the number of states by giving the book stacker more information, telling him he can stack them upright reducing the number of permutations and reducing entropy. In terms of system of particles more energy is more accessible states and so higher entropy?
I'm struggling to see the similarities between having a lack of information and seeing a colder body and wanting give it heat/feel the need to ruin its "order" too and make it disordered.
Thanks for your time
Science news on Phys.org
Thats equation says actually more about temperature than it does about entropy. You can take it as the thermodynamic definition of temperature.
Correct, so the overall entropy increases when heat flows from warm to cold.
You have to be careful with the "order" analogy. It breaks down very rapidly (especially since it can be hard to define what is ordered).
Do you know the difference between a macrostate and a microstate?
Thank you for your reply.
microstates are the different ways you can rearrange your system while remaining in the same macrocscopic state, would that be a correct difference?
Throughout my undergraduate studies senior lectures kept referring to disorder/order, and then when I went online to clarify what it meant people didn't seem to like that definition so I left "disorder" in quotations.
I'm currently doing something on the Ising model, and this was a rabbit hole I entered. I'm trying to solidify my understanding so I can look at what entropy means for the Ising model eg the curie temperature and the break down of magnetism, the relationship between the "disorder" of the spins at high temperature and entropy as well as its involvement in phase transitions (if any)
Macrostates with a greater number of accessible microstates are higher entropy states than macrostates with fewer microstates. Thus the number of high entropy configurations is larger than the number of low entropy configurations. Since the particle dynamics are considered stochastic, these states are selected at random. This means that the system will have a preference for the high entropy states simply because there are more of them.
If the system is allowed to evolve in time from a non-equilibrium state to an equilibrium state, the system will naturally keep moving between macrostates at random until it finds the one with an overwhelmingly large number of microstates. At this point the system will keep randomly selecting this same configuration and will have reached thermal equilibrium. The second law says that this equilibrium state is also a maximum entropy state. Thus states with a large number of microstates correspond to high entropy states. I recently wrote an article detailing this here https://www.physicsforums.com/insights/statistical-mechanics-part-equilibrium-systems/
Thanks very much for your explanation, as well as the article. Cleared a lot up for me!
  • · Replies 17 ·
