Calculating the Frequency of a Tuning Fork Using Resonance Tube Method
The discussion focuses on calculating the frequency of a tuning fork using the resonance tube method, with air column lengths of 48.5 cm and 68.7 cm at 26˚C. The speed of sound in air is approximated at 346.6 m/s, and the wavelength is determined to be half the difference between the two resonance lengths. The formula for the speed of sound is provided, linking it to temperature, and the relationship between frequency and wavelength is highlighted. The calculated frequency of the tuning fork is approximately 857.4 Hz. Understanding whether the tube is open or closed is noted as a potential factor in the calculations.
Shackleford
6. A tuning fork is heard to resonate over a resonance tube when the
air column is 48.5 cm long and again when it is 68.7 cm long. What is
the frequency of the tuning fork if the temperature is 26˚C?
I couldn't figure out how to work this. I thought it mattered if it were in a closed or open pipe, which is not mentioned.
v = 346.6 m/s
I had a problem that was similar to this...if I recall correctly, lambda was .5(D2-D1). So lambda is half the distance between resonances.
>_> However, I am not an expert and could very easily be wrong.
Don't I have to know if it's open or closed?
lambda = 2 (l2 - l2) - .404 m
v = 346.4 ms^-1
f = 857.4 Hz
First you ll need to get the v-air which is given by: v = (332.5)(squareroot(T/273))
where T is the temperature in Kelvin. After that you know that v = f x lambda, and now i think: Ln+1 - Ln = 1/2 lambda.
9K
31K
