Twice differentiable functions
The discussion revolves around a problem set involving a twice differentiable function f defined on an interval [a,b] with specific boundary conditions. The key point is to demonstrate that if f(a) = f(b) = 0 and f(c) > 0 for some c in (a,b), then there exists a point γ in (a,b) where the second derivative f''(γ) is negative. Participants suggest applying Rolle's Theorem and the Mean Value Theorem to find critical points where the first derivative changes sign. By analyzing the intervals [a,c] and [c,b], it is established that there are points u and v where f'(u) > 0 and f'(v) < 0, leading to the conclusion about the second derivative. The original poster successfully resolves the problem with the provided insights.
JamesF
Hi all. Having a little trouble on this week's problem set. Perhaps one of you might be able to provide some insight.
f:[a,b] \rightarrow \mathbb{R} is continuous and twice differentiable on (a,b). If f(a)=f(b)=0 and f(c) > 0 for some c \in (a,b) then \exists \gamma \in (a,b) s.t. f \prime \prime (\gamma) &lt; 0
Rolle's Theorem, MVT, Intermediate Value Theorem
I'm not really sure how to approach the problem. I'm assuming you would apply Rolle's theorem or the Mean Value Theorem, or perhaps the Intermediate Value Property to the problem in order to obtain the solution.
With those theorems we can infer that \exists \theta st f \prime (\theta) = 0
f(c) > 0 so there must be points u,v st f'(u) > 0 and f'(v) < 0
but none of that really gives me any info on the second derivative, which is what I need. I'm sure I'm overlooking something simple as usual, but if anyone could point me in the right direction it would be greatly appreciated.
Look at the MVT on the intervals [a,c] and [c,b]. So, yes, there is a u in (a,c) and a v in (c,b) such that f'(u)>0 and f'(v)<0. Now apply the MVT to f'(x) on the interval [u,v]. The second derivative is the derivative of the first.
thank you very much Dick. You've been extremely helpful as always. I was able to get the answer.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
