Twin Paradox (thorough explanation needed)
190 replies · 30K views · last reply
JesseM said:
You are a fairly good approximation of a "perpetually inertial observer". So, according to your previous comments, you shouldn't have a strong preference for which inertial frame you personally (usually) choose for your own "point-of-view" (POV).
You could choose to use the ordinary wristwatches and measuring tapes that you can buy at numerous retail stores here on Earth (which provide the time and spatial coordinates which Einstein chose to use for any given one of his inertial frames, in his 1905 paper, OR you could choose to use the coordinates of some particular inertial frame that is moving at some given constant velocity very near the speed of light, relative to the (approximately) inertial frame of the Earth.
If you make the latter choice, you will need to acquire and wear a wristwatch that doesn't tick at the same rate that my Timex ticks at. And you will need a measuring tape that is different from those that I've bought at Lowe's hardware store. In fact, you will need to buy one tape for measuring distances along the direction of relative motion, and another tape for measuring distances perpendicular to that direction (and even additional tapes, if you want to measure distances along various other angles to the direction of relative motion).
Presumably, from your previous comments, you really don't have much preference for which of the above two alternative POV's you decide to choose ... they are both equally good.
So, which of those two types of wristwatch have you been using, during your life, so far? Which type of measuring tape?
Mike Fontenot
Mike_Fontenot said:
Mike's even worse off than I thought he was.
Or I could just use the ruler and clock at rest relative to me, and do some simple calculations to figure how any given ruler/clock reading translates into the coordinates of a frame moving at high velocity relative to me. If you want to restrict me to using a coordinate system where I can't do any calculations of this sort, where the coordinates of a given event must be identical to the reading on some physical ruler and clock that were right next to the event when it happened, that would be a new "rule" you never mentioned before (which is itself just an arbitrary aesthetic choice), and applying the same criterion to your CADO system would show it would actually be quite complicated to construct a set of ruler/clocks whose readings matched that system, arguably more so than some other non-inertial systems where (as with CADO) you're at rest at the origin.
JesseM said:
If there's a gravitational field, then in relativity you need the theory of general relativity which explains gravity in terms of curved spacetime, not special relativity which assumes non-curved spacetime. And no coordinate system covering a substantial region of curved spacetime qualifies as "inertial" so the SR time dilation equation won't apply (though in a very small region a freefalling observer can have a "locally inertial frame" according to the equivalence principle). As for your second question:
Doesn't mean to interrupt the conversation, but I have another question.
Suppose the hypothetical example of the twin A and twin B given by me, doesn't involve gravitational field, but instead the gravitational field is replaced by electromagnetic force.
So say the twin A and twin B are actually just 2 magnets (that each has an accelerometer and a clock attached to it), they are not human.
So instead of being pulled by gravity, the magnets(A and B) are pulled by other strong big magnets (that appear and disappear), so the magnets (A and B)depart from each other, then reunite in the middle point again because of magnetic force.
So now, this is non curved space time, so time dilation equation applies. And still no g-force in effect. It appears that A and B is symmetry here. So now which clock run slower? A or B?
Or will both clock run slower? That is, relativity of simultaneity is in effect?
But if relativity of simultaneity is in effect, what the clocks of A and B show when they reunite? Note that the clocks have been synchronized in the beginning of the example, when A and B are 1 meter apart.
In this case, the accelerometer would measure a nonzero g-force, the only way to not feel g-forces is if there aren't any non-gravitational forces acting on you (either inertial motion in flat spacetime, or freefall in a gravitational field)
LightNg said:
So now. In this example there is no g-force. Twin A and twin B appears to be symmetry. Their accelerometers show g-force at all. Now which one of them have the clock run slower?
This example is completely symmetric, so their clocks will be equal when they meet again. However, as JesseM mentioned, actually calculating this would require GR and the simplified equations of SR would not apply.
The accelerometers would read non-zero forces, but there is still symmetry so the clocks will be equal when they meet again.
So, for mutual time dilation to occur without contradiction, I take that it is not possible for 2 objects (object A and object B in my example) to meet again after they depart, at least in the current framework of SR?
What if suddenly a magical portal appear in front of object B, and object B crosses the portal and meet with object A again?
Then what will their clocks read? Hahahaa
Correct, this is a simple geometrical fact. In a flat space two straight lines which are initially diverging can never intersect.
I know bout this geometry, But is there any possibility, or is there any observed phenomena in the universe, that such line be not continuous in space?
Specifically, that the observed movement of an object is not continuous in space?
Ok this is not quite relevant to the topic of this thread, so someone may want to move this post to other thread/forum.
Well, in this case the answer would depend on where in time the portal deposited object B! Because of the relativity of simultaneity, you can't just say that the portal transports B to A's "current" location, because there is no objective-frame independent fact about which event on A's worldline (which reading on its clock) is simultaneous with the event of B first reaching the position of the portal.
Not yet. Even for quantum mechanical systems the wavefunction is continuous in space and time.
