Two batteries and three resistors
1 reply · 5K views · last reply
n.hirsch1
http://session.masteringphysics.com/problemAsset/1122583/1/Walker.21.52.jpg
This is the drawing for the problem
The two questions are:
1) How much current flows through 6.0 V battery when the switch is closed?
2)How much current flows through 6.0 V battery when the switch is open?
I1-I2-I3=0
Kirchoffs rules (charge conservation and loop rule)
I attempted to set up two loops to solve for the current, the first one going around the outside and solving for I3:
0 = 6V - I1R1 - I3R3
I3 = 6V - 5/2I1
Then setting the second loop around the left side of the diagram and solving for I2:
0 = 9V - I1R1 + I2R2
I2 = 9V - 5/4I1
Then using I1 - I2 - I3 = 0 and plugging in the equations above and solving for I1, which I found to be 3.16 A, then continuing to algebraically solve and find I3 as -1.9A and I2 as 5.05 A.
From this point, I am not sure what to do or even if I got the above numbers correct. I tried adding I1 and I3 because that would be the loop that would be used for the 6V if the switch is closed, but that is not correct (1.26 A)
I could use some guidance, thank you very much in advance!
If you have the currents then you can go back and see if in fact that the sum of the voltage drops around any loop is zero.
The physics text by Halliday and Resnick does a similar problem as an example.
