What is the tension in the string between two blocks with friction?
The problem involves two blocks of different masses being pulled across a surface with friction. The original poster has determined the acceleration of the system but is struggling to find the tension in the string connecting the two blocks. The scenario includes forces such as tension, applied force, and friction acting on the blocks.
  • Participants suggest drawing free body diagrams (FBD) for each block and setting up equations based on Newton's second law. There is discussion about the role of friction and how it affects the tension in the string. Some participants question the assumption that the tension is the same throughout the string.
The discussion is active, with participants providing guidance on how to approach the problem. There are multiple interpretations of the equations being set up, and some participants have identified potential mistakes in the original poster's reasoning. The original poster has acknowledged a mistake and is working towards a resolution.
Participants note that the coefficient of friction and the applied force are known, but there may be confusion regarding the frictional forces acting on each block. The original poster is using an online program for validation, which has led to some discrepancies in their calculations.
Mivz18
Ok, I have this problem I've been working on forever, but can't figure out the last part of the question.
A block of mass m1 = 2 kg and a block of mass m2 = 3 kg are tied together and are pulled from rest across the floor by a force of P = 30 N. The coefficient of friction of the blocks with the floor is µ = 0.1.
First it asked what the acceleration of the two blocks were, and I figured that out to be 5.02 m/s ^2 . Then the second part asks what is the tension of the string between the two blocks. This is where my trouble begins.
I know that Fnet = T on m1, unless I'm mistakenly not counting the friction. However, with the force of 30 N to the right and 4.9 N of friction to the left in the system, that is not accounted for in the Fnet of 10.04 N for m1 and 15.06 for m2 that I obtained. If T is the only force on m1, wouldn't T = 10.04 N ?? Please help!
PHP:
[CODE]
You could draw an FBD for both of the blocks with separate tension values for both of the sections of string. Then you should be able to set up, and solve, a system of equations.
You know the acceleration and mass of each block. You also know the applied force and coeff. of friction. Since F_{net}=ma, can you develop the equation to include F_{tension}, which you can then isolate to answer the question?
I had tried developing an equation but it doesn't seem to work like I had stated. Since in m1 Fnet = T, then T should = 10.04 N ? The online program I am using doesn't agree with that answer, so I'm kind of stumped here. I have drawn FBD for both blocks but haven't been able to figure it out. HELP??
Start by indentifying all the horizontal forces on m1. (The tension in the string is not the only force.) Apply Newton's 2nd law.
Ok, maybe I'm missing something but this is what I get:
on m1, of 2 kg, you obtain two forces, that of friction to the left, and that of tension to the right. Therefore, Fnet = T - friction, or T- friction = ma . From the acceleration I obtained in the first part, 5.02 , T - friction = 10.04.
on m2, of 3 kg, I obtain three forces, that of the applied 30 N to the right and that of friction and tension to the left. Fnet = 30 -T - friction , or 30 - T -friction = ma . From the acceleration of 5.02 i get that T + friction = 14.94 .
Then I add the two equations to solve for the variable, Tension, that I'm looking for.
2T = 24.98
T = 12.49
However, the online program disagrees with that answer. Did I calculate something wrong, or am I assuming that the two T's are equal and they really aren't?
Right, but "friction" is not an unknown! Figure it out. Then solve for T. And you're done. :smile:
Right, but not needed. Once again "friction" can be figured out.
Big mistake! The two things you label "friction" are not the same!
nevermind, lol, I found my mistake. I was in the wrong in adding the equations. Instead,
T = 10.04 + friction = 10.04 + 1.96 = 11.98
T = 14.94 - friction = 14.94 - 2.94 = 12
So basically, both are about 12 N , and the online program accepted it. Thanks everyone for your guidance.
Just to be clear: There is only one tension in the string. No need to solve for it twice! (Any difference in the two answers is just due to rounding errors.)
  • · Replies 17 ·
