Two masses and spring oscillation
86 replies · 13K views · last reply
Returning to your energy consideration, and assuming the CM is in rest: If you have two masses with coordinates x1 and x2 corresponding velocities v1 and v2, and you introduce the variable x=x2-x1, the corresponding velocity v=v2-v1:
CM is in rest: m1v1+m2v2=0, and v2-v1=v →
##v_1=-\frac{m_2v}{m_1+m_2}\\v_2=\frac{m_1v}{m_1+m_2}##
The kinetic energy is
##KE=\frac{1}{2} \left(m_1 (\frac{m_2 v}{m_1+m_2} )^2+ m_2( \frac{m_1 v}{m_1+m_2})^2 \right)##
##KE=\frac{1}{2}\frac{m_1 m_2}{m_1+m_2} v^2=\frac{1}{2} μ v^2##
Assuming SHM about the equilibrium value of x: x-xe=Asin(ωt), v=Aωsin(ωt) and expanding the potential energy about xe: PE=0.5 D(x-xe)2
KE+PE=E →
##\frac{1}{2} A^2\left((μω)^2\cos^2(ωt)+D^2 \sin^2(ωt)\right)=E##
The expression can be constant only when μω=D.
Hello ehild
ehild said:
Here is the derivation how a two-body problem can be reduced to one body-problem. I write it in one dimension,but the derivation is the same for 3D.
I would like to understand how this concept of reduced mass is applied in case of a Planet of mass m moving around sun of mass M in circular orbit
Suppose the Sun is considered stationary .In that case ## \frac{GMm}{D^2}=\frac{mv^2}{D}## where D is the distance between them .This gives ##v=\sqrt{\frac{GM}{D}}##
Now if we want to take into account the motion of Sun also i.e both Sun and the planet orbiting about their common COM then this is equivalent to replacing the mass of planet 'm' by reduced mass 'μ = Mm/(M+m)' and replacing the Sun with a central mass 'M+m' .
Using this we have ## \frac{G(M+m)\mu}{D^2}=\frac{mv^2}{D}##
Solving we get ##v=\sqrt{\frac{GM}{D}}## .
I am wondering why hasn't the result changed since now the Sun is also considered to be orbiting ?
No. The reduced-mass approach started by introducing new variables instead of the position vectors of the planet and Sun. You might look at my post in this thread about it.
ehild
By assuming the Sun is stationary, you've reduced the two-body problem to a one-body problem. In this case, you're assuming the Sun doesn't move because its mass M is so much larger than the mass of the planet.
Using the reduced-mass approach instead, you get
$$\frac{GMm}{D^2} = \frac{\mu v^2}{D}.$$ The force between the two bodies remains unchanged, but the mass of moving body is replaced by the reduced mass ##\mu##. When ##M \gg m##, you have ##\mu \cong m##, and you recover the previous result.
I'm not sure how you came up with this.
The two-body Kepler problem can be solved by using the CM mass of reference. The difference of the position vectors obey the same differential equation as a single body with the reduced mass orbiting about a stationary mass of m+M. The gravitational force between the mass and the planet is F= GmM/D2. That between the reduced mass and a central mass of m+M: G μ(M+m)/D2= G(mM/(m+M))(M+m)/D2=GmM/D2.
ehild
Ah, now I understand what Tanya was getting at in her post.
Tanya, you have a mistake in the equation of motion in the second approach, which is why you're ending up with identical results for ##v##. You have to replace ##m## by ##\mu## on the righthand side.
$$ \frac{G(M+m)\mu}{D^2}=\frac{\mu v^2}{D} $$
$$ v^2 = \frac{G(M+m)}{D} $$
$$ v = \sqrt{\frac{GM(1+\frac{m}{M})}{D}} $$
Now ,since ##m<<M## , neglecting term ##\frac{m}{M} ## , ## 1+\frac{m}{M} ≈ 1 ##
$$ v = \sqrt{\frac{GM}{D}} $$
But again this is the same result as before .
Yes, that's correct. You see to that level of approximation, both approaches yield the same result, as you should expect. If you expand ##\sqrt{1+\frac mM}## as a series, you can calculate the higher-order corrections that come from relaxing the assumption that M is stationary.
Suppose I do not consider this two body problem as a one body problem .
Let r1 be the distance of M(sun) from CM and r2 be distance of m(planet) from CM.Then ## r_1 = \frac{mD}{m+M}## and ## r_2 = \frac{MD}{m+M}##
$$ \frac{GMm}{D^2} = \frac{mv^2}{r_2} $$
$$ \frac{GMm}{D^2} = \frac{m(m+M)v^2}{MD} $$
$$ v^2 = \frac{GM^2}{(m+M)D} $$
$$ v = \sqrt{\frac{GM}{(1+\frac{m}{M})D}} $$
Again ## 1+\frac{m}{M}≈ 1 ##
So,
Is this analysis correct ?
The speed v what you get with the reduced mass approach is not the speed of the planet along its orbit about the CM. It is the speed of the hypothetical planet of mass μ orbiting the stationary Sun of mass m+M. Remember we introduced the variable r=r(planet)-r(Sun), and the time derivative of r is the relative velocity of the planet with respect to the Sun.
It is better to get the angular speed. It does not change with the reduced mass approach. So ω^2=G(M+m)/D3. The radii of the orbits both of the planet and the Sun is obtained from the condition that the CM is in rest in the applied frame of reference.
ehild
Yes, but as ehild pointed out, this ##v## isn't the same ##v## as in your previous analyses.
So,
Yes, that is correct. But you want the difference between the cases with stationary Sun and with moving one. And what would you get for double stars, that is two nearly equal masses orbiting about their common CM? Like theese http://astrobob.areavoices.com/2010/04/10/how-to-double-your-enjoyment-of-the-heavens/
ehild
Yes.
ehild said:
And what would you get for a double star, that is two nearly equal masses orbiting about their common CM?
$$ v = \sqrt{\frac{Gm}{2D}} $$ ,where m is the mass of a single star and D is the distance between them.
Well.. it is quite confusing that both post#69 and post#71 are correct ,value of ##v## is coming out same ,yet the ##v## in the two posts are different .
Does ##v## in post#71 represent the linear speed of the planet in circular orbit around the CM ?
In post #69 you got the speed of the reduced-mass hypothetical planet:
[tex]v_r^2=G\frac {m+M}{D}[/tex]
In post #71, you derived the speed of the real planet:
[tex]v^2=G\frac {M^2}{(M+m)D}[/tex]
They are not the same.
$$ \frac{G(M+m)\mu}{D^2}=\mu ω^2D $$
$$ ω^2 = \frac{G(M+m)}{D^3} $$
Now , ## v = ωr_2 ## where ## r_2 = \frac{MD}{m+M}##
$$ v^2 = \frac{G(M+m)}{D^3} (\frac{MD}{m+M})^2 $$
This result matches the one in post#71 .
Is this how you wanted me to approach ?
Yes, it was. :smile: That is the "real" speed of the planet. And the speed of the Sun centre is ωr1
ehild
Thank you very much :)
But I do not understand the importance of this reduced mass approach . We could have calculated the speed as in post#71 .
What could have been asked in the question where the conversion of two body problem in one would have been a superior approach ?
How would you solve the problem of double stars in general ( not assuming circular orbit)? When you need the period and the data of the orbits?
ehild
OK.
Please have a look at the attachment .I have attached portion of a chapter in the book.
The motion of a planet is analogous to that of an electron revolving the nucleus just like in Bohr Model of the hydrogen atom .
If the nucleus is considered stationary then $$ \frac{1}{4\piε_0}\frac{e^2}{r^2}
= \frac{mv^2}{r} $$
But if take into account the motion of nucleus around the CM ,then do we simply replace ##m## by ##\mu ## where ##\mu =\frac{mM}{m+M}## ,where m is the mass of electron and M is the mass of proton(nucleus).
The LHS in both the cases remain same whereas the RHS in the stationary case has ##m## and the moving nucleus case has ##\mu## .
$$ \frac{1}{4 \piε_0}\frac{e^2}{r^2} = \frac{\mu v^2}{r} $$
But this is not correct because the 'v' in this case is that of the hypothetical reduced mass ,not the actual speed of the electron.
What is your opinion ? Is the book getting it wrong or am I interpreting it incorrectly ?
  • Diagram of the nucleus and electron orbiting their common center of mass (cm), with radii r_N and r_e and total separation r, labeled Fig. 39.26; the proton and electron both revolve in circular orbits.
Here the force is proportional to the product of charges instead of the product of the masses.
ehild
Tanya Sharma said:
Well, it is quite confusing that both post#69 and post#71 are correct, value of ##v## is coming out same, yet the ##v## in the two posts are different .
Try calculating ##v_1## and ##v_2##, the speed of each body relative to the CM, using your approach in post 71. The bodies move in opposite directions, so their relative speed is given by ##v_1+v_2##. Calculate that sum and compare it to the result you got in post 69. Don't make any approximations based on the assumption that ##M \gg m##.
ehild
Right . But according to book ,if we need to account for the motion of nucleus we simply need to replace ##m## by ##\mu## to get the speed .(Or am I understanding it incorrectly)
This gives $$v^2 = \frac{1}{4 \piε_0}\frac{e^2(m+M)}{rmM}$$
But this is incorrect value of speed .
The correct result can be obtained on similar lines to post#71 .
$$ \frac{1}{4 \piε_0}\frac{e^2}{r^2} = \frac{mv^2}{r_2} $$ ,where ##r_2 = \frac{Mr}{m+M}## is the distance of the electron from the CM .
$$v^2 = \frac{1}{4 \piε_0}\frac{e^2M}{rm(m+M)}$$ . This is the correct speed .
How is book interpretation correct ?
You're comparing apples to oranges. Reread the first part of post 72 and do the calculation I suggested in post 84. Hopefully, that will clear up your confusion.
The Bohr model predicts the spectrum of hydrogen atom. It postulates that the angular momentum is integer multiple of (h/2pi) and determines the possible energy levels. The angular momentum and the energy are those of the whole Hydrogen atom. The angular momentum and energy of the whole atom can be considered as those of a single particle with mass equal to the reduced mass of the electron-nucleus system. https://www.google.com/url?sa=t&rct...mG2jGkozqYJcq5A&bvm=bv.68445247,d.bGQ&cad=rjt
The reduced mass correction explains the isotope shift of the spectral lines of Deuterium. In case of stationary nuclei, the spectra of both the Hydrogen and the Deuterium atoms would be the same.
ehild
