Two masses attached by a spring
  • Thread starter Thread starter Starproj
    Spring Two masses
The discussion centers on the dynamics of two unequal masses, m1 and m2, connected by a spring with a spring constant k on a frictionless surface. The user initially solved the problem using the center of mass and reduced mass to find the frequency but was later tasked with deriving the equations of motion. The equations are established as m1a1 = -k(x1 - x2 + l) and m2a2 = -k(x2 - x1 - l). The user seeks clarification on the significance of the length l in the equations, concluding that it is necessary due to the coordinate system used, where x1 and x2 are measured from the same origin.
  • Understanding of Newton's laws of motion
  • Familiarity with spring dynamics and Hooke's Law
  • Knowledge of oscillatory motion and frequency calculation
  • Concept of center of mass and reduced mass
  • Study the derivation of equations of motion for coupled oscillators
  • Explore the concept of reduced mass in multi-body systems
  • Learn about the implications of coordinate systems in mechanical problems
  • Investigate the role of equilibrium length in spring dynamics
Physics students, mechanical engineers, and anyone studying oscillatory systems and spring dynamics.
Starproj
I am studying the problem of two masses, m1 and m2 (not equal) attached by a spring of spring constant k on a frictionless surface set into oscillatory motion (unstretched spring is of length l, x1 < x2). When I first attacked this problem, I let the origin be the center of mass, calculated the reduced mass, and was able to get the frequency, etc. While this yielded the correct answer, I have now been asked to solve it setting up the equations of motion. I deduce that they are
m1a1=-k(x1-x2+l)
m2a2=-k(x2-x1-l)
Can someone help me understand the notion of l? That is, for mass 1 is l positive because it is in the positive direction and vice-versa? I can solve it mathematically from there, but it makes me uncomfortable not fully understanding how the equations got set up.
Thanks in advance!
The best way to see it is like this.
Write down an expression for the extension (i.e. difference from original length) of the spring as a function of x_1 and x_2 (draw a diagram if you need).
Consider in which direction each of m_1 and m_2 would be accelerated by a positive extension. This should make everything clear...
...let me know if it doesn't!
Hi,
Thanks for replying. I have been looking at this problem from many different angles trying to determine why the prof included the value l. I found a great website that shows a much more complicated problem, but the process is basically the same:
http://www.efunda.com/formulae/vibrations/mdof_eom.cfm
I have concluded that the length l does not need to be included in the equations of motion, particularly since the time derivative of it would be zero and it falls out anyway. The only other trick I have noticed with these problems is that you have to take care of the signs and not just knee-jerk a -k.
*sigh* Maybe I should become a psychology major!
The reason the example you cite does not include spring lengths is because it is assuming that the springs are all at their natural lengths when the displacement variables of the various masses (x_i) are all zero. In other words, the positions of the various masses are all measured from different origins.
In the problem set out by your professor, x_1 and x_2 are measured from the same origin. Thus the spring is not at its equilibrium length when x_1=x_2=0. Thus, using this coordinate system you do need to have l in the equations.
  • · Replies 17 ·
  • · Replies 16 ·
