arpon said:
Consider two coordinate systems on a sphere. The metric tensors of the two coordinate systems are given. Now how can I check that both coordinate systems describe the same geometry (in this case spherical geometry)?
(I used spherical geometry as an example. I would like to know the process in general.)
Any method I can think of involves finding the transformation equations between the two coordinate systems. Though it seems like there should be a better way. In special cases there certainly may be, but I'm not sure if there is in general a better way or not.
Once you have those, there are several ways to proceed, but your idea of showing that said transformation equations do in fact transform the first metric into the second via the tensor transformation rules seems to be the most direct, if carried out correctly.
I'd start out by writing out the transformation equations. Primed/unprimed notation gets a bit confusing, I think, it would probably be better to use different symbols for the two coordinate systems.
So you might use ##x^1, x^2, x^3## and ##\chi^1, \chi^2, \chi^3## for the two sets of coordinates, then in the 3 dimensional case you'll have three functions for the transformation, for instance you might write ##\chi^1## as a function of x^1, x^2, x^3. Or you could write x^1 as a function of ##\chi^1, \chi^2, \chi^3##. Similarly for the other components.
We will get an overdetermined set of equations. Making use of the fact that the metric tensor is symmetric, in 2 dimensions we'll have 3 constraint equations in two unknowns, in 3 dimensions 6 constraints in 3 unknowns, in 4 dimensions 10 constraints in 4 unknowns.
