Two particles in a magnetic field
In a discussion about two particles in a magnetic field, it is established that particle Y, with double the charge of particle X, experiences double the electric force but not double the magnetic force due to differing velocities. The participants analyze the time taken by each particle to complete a half-circle path, initially struggling with the relationship between radius and speed. Ultimately, it is confirmed that the time for particle Y is half that of particle X, as derived from relevant equations. The clarification provided helps resolve confusion regarding the calculations involved. The discussion emphasizes the importance of understanding the effects of charge and mass in magnetic fields.
sony
Illustration:
http://home.no.net/erfr1/images/2.jpg
"A particle, X with mass m and charge q starts with an inital velocity zero, and follows the red path indicated on the drawing. It follows a half circle when entering the magnetic field.
A new particle, Y with mass m(same) and charge 2q starts from the same place as X. Is the following true og untrue:
1. The force on Y is double the force on X in the electric field.
2. The force on Y is double the force on X in the magnetic field.
3. The time Y uses on the half circle is half the time X uses.
1. Fex=qE and Fey=2qE. So that's true.
2. Fmx=qvB = q*sqrt(qU/m) * B.
And Fmy = qvb = 2q * sqrt(2qU/m) * B. So this statement is false.
3. I don't get this.
It's half a circle, so v=Pi*r/T
And I have tried the formula: v^2/r = 4Pi^2*r / T^2
But everything I use involves either v, or r og both. And the radius of Y has to be smaller right? Since the mag. force on Y is the biggest. But I don't know the radius! And the speed is such an ugly expression, and I always end up with the square root of an expression, so the difference can't be 1/2.
The book says that statement 3 is true...
Please help.
Thanks
T_{X}=\frac{\pi r_{X}}{v_{x}} (1)
T_{Y}=\frac{\pi r_{Y}}{v_{Y}} (2)
r=\frac{mv}{qB} (3)
Use (3) for the 2 particles and then combine with (1) & (2) to reach the result.
Daniel.
Aaaah! Thank you. So the speed is ruled out and I get:
Tx= Pi*m/qB
Ty=1/2 * Pi*m/qB
Ty=1/2Tx
I can't believe I spent so much time on this :). Stupid me.
Thanks!
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
